[mapserver-users] High resolution printing
Armin Burger
armin.burger at gmx.net
Wed Oct 1 17:03:37 EDT 2008
Milo
Depending on the purpose, you could check if Mapyrus is useful for you.
Disadvantage is that you need to define the map layout a second time and
make it look similar to Mapserver layout. But the PDF output quality is
far better than the one of Mapserver, and you do not need to bother with
PDFLib licenses. And it's also working well for large print formats
(vector based rendering of vector data).
Armin
On 30/09/2008 18:26, Milo van der Linden wrote:
> Hello list!
> I have been searching the web for tips and tricks, but basically what I
> need is a method or procedure or (commercial) tool that can enhance my
> mapserver installation to enable high resolution printing.
> What I am looking for is the best practice to:
> - Add a button to our website
> - Let the button start a script or program that processes the active
> layers in the map view based upon the current extent
> - Generate a mixture of high-res images and optionally svg or alike for
> linework
> - combine the works in a pdf
> - present the pdf for download to the user
> I would also like to know if there are any commercial, mapserver based,
> solutions for this. I am also willing to hire an expert to achieve this.
> Any ideas?
> Kind regards,
> Milo van der Linden
> mapserver-users at lists.osgeo.org
