[mapserver-users] WMS in Google Earth
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Oct 2 17:15:19 EDT 2008
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Alexandre Dube
> Sent: 02 October, 2008 4:40 PM
> To: MAPSERVER USERS
> Subject: Re: [mapserver-users] WMS in Google Earth
> Back with my local WMS on GE problem. I think it has
> something to do with the wms_onlineresource in WEB METADATA.
> I downloaded the gmap datas, which are already in GE as the
> last WMS service available, to be able to test locally what
> is already working on the internet. At first, it worked in
> GE. Then, I noticed that the wms_onlineresource was set to :
> "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
> which seemed wrong to me, because my other map doesn't exist
> on the internet, only locally.
> So I changed it to :
> "http://127.0.0.1:port/cgi-bin/mapserv?map=/my/local/path/gmap
> 75_wms.map&"
> and then I doesn't work anymore... also tried :
> "http://127.0.0.1:port/cgi-bin/mapserv?"
> no result...
> I must be close the the answer. I have searched a lot over
> the internet but I haven't found anything yet. Any hints ?
> Alexandre
> Alexandre Dube wrote:
> > Hi list,
> > I'm trying to figure how to setup my own wms layer in GE. So far,
> > I'm able to see each layer in the "WMS Parameters", but if I select
> > any, I get a big red X, meaning it's not working...
> > If I copy the "Link" created by GE, paste it in a browser, add
> > "&SERVICE=WMS&BBOX=-180,-90,180,90", then I get a map. So, I don't
> > really know what I'm missing here. Any hint ? I use
> mapserver 5.2.0
> > on Linux.
This might be due to the SERVICE parameter missing WMS GetMap request.
If you, once you add the layer, right click and select "Properties",
adding "&service=WMS" to the Link string, you should be able to get a
valid map image returned.
That said, I thought we lifted the service param from WMS GetMap
requests (GetMap sans service= works for me in svn trunk).
..Tom
