[mapserver-users] Draw point on a polygonlayer
Hallgren, Johan
johan.hallgren at logica.com
Mon Oct 6 15:34:12 EDT 2008
I have it in Oracle. I will try the same there.
Thanks
Johan
Johan Hallgren
Logica
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.hallgren at logica.com<mailto:johan.hallgren at logica.com>
http://www.logica.se<http://www.logica.se/>
Sent: den 6 oktober 2008 18:02
To: Hallgren, Johan
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Draw point on a polygonlayer
If it is stored in PostGIS, maybe could you create a view that is the centerpoints of the polys, and then create a new mapserver layer that uses the view as the data source?
On Mon, Oct 6, 2008 at 5:56 AM, Hallgren, Johan <johan.hallgren at logica.com<mailto:johan.hallgren at logica.com>> wrote:
Hello,
Is there some way to define a layer so it will draw a centerpoint for a polygon layer. I could use an annotaion layer type, but in that case, the legend will show the label, and not the point symbol.
Any ideas?
/Johan
Johan Hallgren
Logica
Pelle Bergs backe 3
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081006/34fbc46b/attachment-0001.html
