[mapserver-users] spatial and time index
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 6 19:05:51 EDT 2008
Zhao Peisheng,
I'm sorry, but I don't really know much about how the time dimension
support works in MapServer. After reviewing the applicable howto's
I'd suggest you ask on mapserver-users.
Good luck,
On Mon, Oct 6, 2008 at 11:55 AM, zhao peisheng <zhaops at hotmail.com> wrote:
> Now I use gdaltindex to build a set of tile index SHP for a time-series
> data. And I put this SHPs into PostGIS But I don't know how to configure the
> tileindex in Map file. I tried to do like this. PostGIS can return the
> correct SHP file with time filter, but MapServer think it is a data file,
> not tile file, and draw failed. How to figure it out? Thanks.
> LAYER
> STATUS ON
> NAME "AIRSSO2MAPAIDX"
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=mapserver password=anonymous user=anonymous
> port=5432"
> DATA "the_geom from airs_so2_map_a"
> METADATA
> "wms_title" "AIRS SO2 Map Total Ascending INDEX"
> "ows_service" "none"
> END
> END
> # AIRS SO2 Map Ascending Layer
> LAYER
> NAME 'AIRS_SO2_A'
> TYPE RASTER
> STATUS ON
> DEBUG ON
> DUMP TRUE
> PROCESSING "DITHER=YES"
> PROJECTION
> "init=epsg:4326" ##recommended
> END
> METADATA
> wms_title "AIRS_SO2_A" ##required
> wms_timeextent "2008-09-18/2008-10-02"
> wms_srs "EPSG:4326"
> wms_timeitem "time"
> wms_timedefault "2008-10-02"
> wms_extent "-180.0 -90.0 180.0 90.0"
> END
> TILEITEM "location"
> TILEINDEX "AIRSSO2MAPAIDX"
> END # Layer
> ________________________________
> Get more out of the Web. Learn 10 hidden secrets of Windows Live. Learn Now
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | Geospatial Programmer for Rent
