[mapserver-users] changing rendered color of layer
dynamically?
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Oct 6 10:21:37 EDT 2008
Nikos: There can be more than one style in a class to you'd need the array notation there too:
&map.layer[oikismoi].class[oikismoi].style[0].color+230+34+35
Does that work?
Steve
>>> <nikos at maich.gr> 10/06/08 8:18 AM >>>
Hello all,
I've been scratching my head as to how to change the color that a layer
maybe rendered via a form. My users want to select which color the layers
should be rendered.
Would appreciate a bit of insite. I'm using FW MS 5.1-dev
I've tried, according to the docs, using layer and class names as well as
layer and class index and neither work...
&map.layer[oikismoi].class[oikismoi].style.color+230+34+35
&map.layer[0].class[0].style.color+230+34+35
In MS 4.something, I used to use "map_layer_0_class_0_color=255+0+0"
successfully
I've also tried to use something like
CLASS # layer color change
EXPRESSION '%layer_color%'
style
backgroundcolor 128 128 128
color 2 2 220
outlinecolor 150 150 150
end
END
to at least statically test a substitution, but fail...
below is a snip from my mapfile,
sincerely,
nikos
LAYER
debug 5
classitem "OBJECTID"
data "LANDUNIT_KARDITSA"
footer "LANDUNIT_KARDITSA_footer.html"
group "LANDUNIT_KARDITSA"
header "LANDUNIT_KARDITSA_header.html"
labelcache on
labelitem "OBJECTID"
name "LANDUNIT_KARDITSA"
postlabelcache true
status on
type polygon
OPACITY 70
# 1 class LANDUNIT_KARDITSA
class
name "KARDITSA"
style
#color 133 234 21
color 22 200 22
outlinecolor 50 50 50
end
template "LANDUNIT_KARDITSA_query.html"
end
end
LAYER
DEBUG 5
data "oikismoi"
footer "oikismoi_footer.html"
group "oikismoi"
header "oikismoi_header.html"
labelcache on
name "oikismoi"
postlabelcache true
status on
type polygon
# 1 class oikismoi
class
name "oikismoi"
style
backgroundcolor 0 128 128
color 22 122 233
outlinecolor 0 0 0
end
template "oikismoi_query.html"
end
end
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
