[mapserver-users] Display road layer realistically
    Steve Lime
    Steve.Lime at dnr.state.mn.us
    Mon Oct  6 21:41:02 PDT 2008
Man, I don't know how. You'd have to pre-process your data somehow to identify coincident
line segments and offset them accordingly. That can't be done on-the-fly.
As for your base layer definition, it's about as boring as it gets - fat red line, with black
text. Simple things like adding a wide background:
      STYLE
          COLOR 0 0 0   # fat black line
          WIDTH 6
       END
      STYLE
          COLOR 255 0 0    # thinner red line
          WIDTH 4
       END
can help. Outline colors for labels can also make them easier to read. I talk to a graphic
designer or cartographer if you have access to one for recommendations and then develop
to that. Also, AGG as a render will produce higher quality output than GD, use that if possible.
Steve
>>> Adrian Popa <adrian_gh.popa at romtelecom.ro> 10/06/08 6:05 AM >>>
Hello everybody,
I have to draw a fiber-optic layer that can be interpreted like a road
layer (polyline data type). I've drawn it in simple ways (colored
lines), but now it must look more professional... I would like some tips
on how to draw this/color schemes to make it look better.
LAYER
    NAME fibraProblems
    TYPE LINE
    STATUS off
    DATA fibra
    CLASSITEM "nume"
    LABELITEM "nume"
    CLASS
       Name "Selected"
       EXPRESSION /selected/
       STYLE
          COLOR 255 0 0
          WIDTH 4
       END
       LABEL
            COLOR 0 0 255
            TYPE TRUETYPE
            FONT arial
            SIZE 8
            ANTIALIAS TRUE
            POSITION AUTO
            PARTIALS TRUE
            MINDISTANCE 0
            BUFFER 0
    #       PRIORITY 5
       END
   END
END
Also, on some parts of the fiber, there are multiple fibers going the
same way... I would like to represent them like in this subway map:
http://www.frenchculture.com/images/metro_map.gif, meaning adjacent
fibers should apear next to each-other. Any idea if this can be done
with mapserver?
Thank you,
Adrian
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
