[mapserver-users] Creating legend
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Oct 7 09:31:49 EDT 2008
There's nothing you have to do on the MapServer side. Looks like your OL config is wrong
though. I think 'singleTile' is set in the wrong configuration object, perhaps others are in
the wrong place too.
Steve
>>> Subha Ramakrishnan <subha at gslab.com> 10/07/08 1:30 AM >>>
I am using mapserver 5.0.2 with openlayers.
I've a problem while creating a legend for a map from mapserver.When i
try to overlay the image from the mapserver on openlayers' base map, the
images are rendered in tiles, and every tile has a legend and is limited
by the size of the tile. So, i see lots of legends on the map and only
half of them are visible as it is restricted by the tile size.
This is my request to mapserver from openlayers
var mapfile = layer_tablename+'.map';
twms1 = new OpenLayers.Layer.WMS(
layer_tablename,"http://localhost/cgi-bin/mapserv?",
{ map: mapfile,
transparent: 'true', layers:layer_tablename,
format: 'image/png',
projection:"EPSG:4326",reproject:false,
units: "m",
singleTile: true
},{numZoomLevels : MaxZoomLevel});
map.addLayer(twms1);
I am using the option of singleTile. Is there any setting to be done in
the map file or mapserver for it render a single tile/single legend per
image?
Thank you.
Regards,
Subha
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
