[mapserver-users] nfs drive
Dan Little
danlittle at yahoo.com
Wed Oct 8 16:51:58 EDT 2008
You have to have the drive mounted for whatever user that is, not just as your self.
You'll have to excuse me if I cannot give you specific enough details, I'm generally a Unix/Linux guy and tend to need to work with Windows' face-to-face to figure stuff out.
----- Original Message ----
> From: zach cruise <zachc1980 at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Cc: Dan Little <danlittle at yahoo.com>; Minka Stoyanova <minka.stoyanova at gmail.com>
> Sent: Wednesday, October 8, 2008 3:37:33 PM
> Subject: Re: [mapserver-users] nfs drive
> double checked!
> local *.map can access *.shp on remote/nfs g:.
> but local *.html can't access *.map on remote/nfs g: ??
> anyway how do i allow webserver "user" access to remote/nfs?
> On Wed, Oct 8, 2008 at 4:23 PM, Dan Little wrote:
> > If the NFS drive is mapped to "G:" and the file "G:/nfs.map" exists (double
> check that), then you have a permissions error. The web server "user" doesn't
> have permission to access that directory.
> >> From: zach cruise
> >> Cc: Dan Little ; Minka Stoyanova
> >> Sent: Wednesday, October 8, 2008 3:17:41 PM
> >> you mean
> >> http://127.0.0.1/cgi-bin/mapserv?map=g:/nfs.map ??
> >> where g: is the mapped drive.
> >> it doesn't work.
> >> msLoadMap(): Unable to access file. (g:/nfs.map)
> >> On Wed, Oct 8, 2008 at 4:06 PM, Dan Little wrote:
> >> > You can use NFS.
> >> > If you're using Windows and have mapped the drive then the path is just
> like
> >> it is in Explorer.
> >> > In Linux/UNIX, then the path is where you mounted it.
> >> >> From: zach cruise
> >> >> Sent: Wednesday, October 8, 2008 3:01:54 PM
> >> >> can i put *.map on remote nfs (keeping mapserv cgi on local)? if yes
> >> >> how to reference it
> >> >> http://127.0.0.1/cgi-bin/mapserv?map=//123.4.5.6/nfs.map ??
> >> >> any one notice any lag with nfs? tips??
> >> >> On Thu, Oct 2, 2008 at 3:46 PM, Minka Stoyanova
> >> >> wrote:
> >> >> > Why in your path descriptions do you mix slashes and backslashes?
> >> >> > On Thu, Oct 2, 2008 at 8:52 PM, zach cruise wrote:
> >> >> >> unable to map data (cities.shp) on nfs drive (g:). data pulls into
> >> >> >> qgis fine. know it can be done-
> http://www.nabble.com/Re%3A-Server---map-files-on-differing-machines-p11660547.html,
> http://www.nabble.com/Re%3A-How-best-to-serve-very-large-%28300GB%29-raster-data--p16785070.html
> >> >> >> MAP
> >> >> >> # SHAPEPATH "g:\"
> >> >> >> SHAPEPATH \\123.4.5.6\vol\data\
> >> >> >> LAYER
> >> >> >> # DATA "poly/cities"
> >> >> >> DATA "poly/cities"
> >> >> >> END
> >> >> >> END
> >> >> >> _______________________________________________
> >> >> >> mapserver-users mailing list
> >> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
