[mapserver-users] nfs drive
zach cruise
zachc1980 at gmail.com
Wed Oct 8 16:37:33 EDT 2008
double checked!
local *.map can access *.shp on remote/nfs g:.
but local *.html can't access *.map on remote/nfs g: ??
anyway how do i allow webserver "user" access to remote/nfs?
On Wed, Oct 8, 2008 at 4:23 PM, Dan Little <danlittle at yahoo.com> wrote:
> If the NFS drive is mapped to "G:" and the file "G:/nfs.map" exists (double check that), then you have a permissions error. The web server "user" doesn't have permission to access that directory.
> ----- Original Message ----
>> From: zach cruise <zachc1980 at gmail.com>
>> To: mapserver-users at lists.osgeo.org
>> Cc: Dan Little <danlittle at yahoo.com>; Minka Stoyanova <minka.stoyanova at gmail.com>
>> Sent: Wednesday, October 8, 2008 3:17:41 PM
>> Subject: Re: [mapserver-users] nfs drive
>> you mean
>> http://127.0.0.1/cgi-bin/mapserv?map=g:/nfs.map ??
>> where g: is the mapped drive.
>> it doesn't work.
>> msLoadMap(): Unable to access file. (g:/nfs.map)
>> On Wed, Oct 8, 2008 at 4:06 PM, Dan Little wrote:
>> > You can use NFS.
>> > If you're using Windows and have mapped the drive then the path is just like
>> it is in Explorer.
>> > In Linux/UNIX, then the path is where you mounted it.
>> >> From: zach cruise
>> >> Sent: Wednesday, October 8, 2008 3:01:54 PM
>> >> can i put *.map on remote nfs (keeping mapserv cgi on local)? if yes
>> >> how to reference it
>> >> http://127.0.0.1/cgi-bin/mapserv?map=//123.4.5.6/nfs.map ??
>> >> any one notice any lag with nfs? tips??
>> >> On Thu, Oct 2, 2008 at 3:46 PM, Minka Stoyanova
>> >> wrote:
>> >> > Why in your path descriptions do you mix slashes and backslashes?
>> >> > On Thu, Oct 2, 2008 at 8:52 PM, zach cruise wrote:
>> >> >> unable to map data (cities.shp) on nfs drive (g:). data pulls into
>> >> >> qgis fine. know it can be done-
>> http://www.nabble.com/Re%3A-Server---map-files-on-differing-machines-p11660547.html,
>> http://www.nabble.com/Re%3A-How-best-to-serve-very-large-%28300GB%29-raster-data--p16785070.html
>> >> >> MAP
>> >> >> # SHAPEPATH "g:\"
>> >> >> SHAPEPATH \\123.4.5.6\vol\data\
>> >> >> LAYER
>> >> >> # DATA "poly/cities"
>> >> >> DATA "poly/cities"
>> >> >> END
>> >> >> END
>> >> >> _______________________________________________
>> >> >> mapserver-users mailing list
>> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
