[mapserver-users] nfs drive
Dan Little
danlittle at yahoo.com
Wed Oct 8 16:23:27 EDT 2008
If the NFS drive is mapped to "G:" and the file "G:/nfs.map" exists (double check that), then you have a permissions error. The web server "user" doesn't have permission to access that directory.
----- Original Message ----
> From: zach cruise <zachc1980 at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Cc: Dan Little <danlittle at yahoo.com>; Minka Stoyanova <minka.stoyanova at gmail.com>
> Sent: Wednesday, October 8, 2008 3:17:41 PM
> Subject: Re: [mapserver-users] nfs drive
> you mean
> http://127.0.0.1/cgi-bin/mapserv?map=g:/nfs.map ??
> where g: is the mapped drive.
> it doesn't work.
> msLoadMap(): Unable to access file. (g:/nfs.map)
> On Wed, Oct 8, 2008 at 4:06 PM, Dan Little wrote:
> > You can use NFS.
> > If you're using Windows and have mapped the drive then the path is just like
> it is in Explorer.
> > In Linux/UNIX, then the path is where you mounted it.
> >> From: zach cruise
> >> Sent: Wednesday, October 8, 2008 3:01:54 PM
> >> can i put *.map on remote nfs (keeping mapserv cgi on local)? if yes
> >> how to reference it
> >> http://127.0.0.1/cgi-bin/mapserv?map=//123.4.5.6/nfs.map ??
> >> any one notice any lag with nfs? tips??
> >> On Thu, Oct 2, 2008 at 3:46 PM, Minka Stoyanova
> >> wrote:
> >> > Why in your path descriptions do you mix slashes and backslashes?
> >> > On Thu, Oct 2, 2008 at 8:52 PM, zach cruise wrote:
> >> >> unable to map data (cities.shp) on nfs drive (g:). data pulls into
> >> >> qgis fine. know it can be done-
> http://www.nabble.com/Re%3A-Server---map-files-on-differing-machines-p11660547.html,
> http://www.nabble.com/Re%3A-How-best-to-serve-very-large-%28300GB%29-raster-data--p16785070.html
> >> >> MAP
> >> >> # SHAPEPATH "g:\"
> >> >> SHAPEPATH \\123.4.5.6\vol\data\
> >> >> LAYER
> >> >> # DATA "poly/cities"
> >> >> DATA "poly/cities"
> >> >> END
> >> >> END
> >> >> _______________________________________________
> >> >> mapserver-users mailing list
> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
