[mapserver-users] nfs drive
zach cruise
zachc1980 at gmail.com
Wed Oct 8 16:17:41 EDT 2008
you mean
http://127.0.0.1/cgi-bin/mapserv?map=g:/nfs.map ??
where g: is the mapped drive.
it doesn't work.
msLoadMap(): Unable to access file. (g:/nfs.map)
On Wed, Oct 8, 2008 at 4:06 PM, Dan Little <danlittle at yahoo.com> wrote:
> You can use NFS.
> If you're using Windows and have mapped the drive then the path is just like it is in Explorer.
> In Linux/UNIX, then the path is where you mounted it.
> ----- Original Message ----
>> From: zach cruise <zachc1980 at gmail.com>
>> To: mapserver-users at lists.osgeo.org
>> Sent: Wednesday, October 8, 2008 3:01:54 PM
>> Subject: Re: [mapserver-users] nfs drive
>> can i put *.map on remote nfs (keeping mapserv cgi on local)? if yes
>> how to reference it
>> http://127.0.0.1/cgi-bin/mapserv?map=//123.4.5.6/nfs.map ??
>> any one notice any lag with nfs? tips??
>> On Thu, Oct 2, 2008 at 3:46 PM, Minka Stoyanova
>> wrote:
>> > Why in your path descriptions do you mix slashes and backslashes?
>> > On Thu, Oct 2, 2008 at 8:52 PM, zach cruise wrote:
>> >> unable to map data (cities.shp) on nfs drive (g:). data pulls into
>> >> qgis fine. know it can be done-
>> http://www.nabble.com/Re%3A-Server---map-files-on-differing-machines-p11660547.html,
>> http://www.nabble.com/Re%3A-How-best-to-serve-very-large-%28300GB%29-raster-data--p16785070.html
>> >> MAP
>> >> # SHAPEPATH "g:\"
>> >> SHAPEPATH \\123.4.5.6\vol\data\
>> >> LAYER
>> >> # DATA "poly/cities"
>> >> DATA "poly/cities"
>> >> END
>> >> END
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
