[mapserver-users] nfs drive
Dan Little
danlittle at yahoo.com
Wed Oct 8 16:06:16 EDT 2008
You can use NFS.
If you're using Windows and have mapped the drive then the path is just like it is in Explorer.
In Linux/UNIX, then the path is where you mounted it.
----- Original Message ----
> From: zach cruise <zachc1980 at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Sent: Wednesday, October 8, 2008 3:01:54 PM
> Subject: Re: [mapserver-users] nfs drive
> can i put *.map on remote nfs (keeping mapserv cgi on local)? if yes
> how to reference it
> http://127.0.0.1/cgi-bin/mapserv?map=//123.4.5.6/nfs.map ??
> http://127.0.0.1/cgi-bin/mapserv?map=g:/nfs.map ??
> any one notice any lag with nfs? tips??
> On Thu, Oct 2, 2008 at 3:46 PM, Minka Stoyanova
> wrote:
> > Why in your path descriptions do you mix slashes and backslashes?
> > On Thu, Oct 2, 2008 at 8:52 PM, zach cruise wrote:
> >> unable to map data (cities.shp) on nfs drive (g:). data pulls into
> >> qgis fine. know it can be done-
> http://www.nabble.com/Re%3A-Server---map-files-on-differing-machines-p11660547.html,
> http://www.nabble.com/Re%3A-How-best-to-serve-very-large-%28300GB%29-raster-data--p16785070.html
> >> MAP
> >> # SHAPEPATH "g:\"
> >> SHAPEPATH \\123.4.5.6\vol\data\
> >> LAYER
> >> # DATA "poly/cities"
> >> DATA "poly/cities"
> >> END
> >> END
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
