[mapserver-users] Trouble with IIS/WMS service in ArcGIS
Milo van der Linden
mlinden at zeelandnet.nl
Thu Oct 9 17:26:53 EDT 2008
Make sure that the directory where the temporary map images /ms_tmp/ are
stored is accessible by your server's IIS_XXUSER otherwise no images
will be served.
Don't trust IIS to arrange this for you, you have to set it yourself at
system level.
Bistrais, Bob wrote:
> I suppose this is more of an ArcGIS question, so I apologize if it's not
> appropriate here, but perhaps somebody has a suggestion. We have a
> MapServer WMS service. It is running on a server which uses IIS instead
> of Apache. We are trying to consume it through ArcGIS. I can make the
> connection in ArcCatalog, and the properties look correct. But the data
> (which is imagery) cannot be seen in ArcGIS, only a white space. The
> spatial extent looks correct.
> We had the same imagery in a WMS service, on an Apache server, and it
> works fine with ArcGIS. Does anyone have any suggestions?
> Thanks,
> Bob
> mapserver-users at lists.osgeo.org
