[mapserver-users] Disappearing point in a map
Chip Taylor
work at xwb.com
Fri Oct 10 17:53:00 EDT 2008
I have a map where I pass in the information about a point via the URL. I am
using mapserver version 5.2 on a Windows Server 2000. In some cases the
point just does not appear. For example, the map extents of
-78.9043321338311+35.0222546417047+-78.8914558661689+35.0367113582953 will
not show a point at -78.897894, 35.029483 and yet a map extents of
-78.9041121338311+35.0222546417047+-78.8912358661689+35.0367113582953 will
show the point of -78.897674, 35.029483, less than 300 linear feet away.
Here is the URL passing in the first example:
https://devmap/bin/mapserv.exe?mode=map&map=map_files/US.map&mapsize=580
475&map_MyPoint_feature=new&map.layer[MyPoint]=feature+points+-78.897894+35.
029483+END+TEXT+%27Secondary%20Building%27END&layers=roads&mapext=-78.904332
1338311+35.0222546417047+-78.8914558661689+35.0367113582953&program=%2Fbin%2
Fmapserv.exe
And here is the mapfile:
MAP
NAME "US"
STATUS ON
UNITS DD
EXTENT -127.00 43.00 -115.00 50.00
SIZE 500 400
IMAGECOLOR 156 188 217
IMAGETYPE png
SYMBOLSET "../etc/NAVsymbols.sym"
SHAPEPATH "../Shape_Files/navteq_data/"
FONTSET "../etc/fonts.txt"
Include "InlineSyms.map"
# Symbol for drawing Star
Symbol
NAME 'Star'
TYPE VECTOR
FILLED true
POINTS
0 0.375
0.35 0.375
0.5 0
0.65 0.375
1 0.375
0.75 0.625
0.875 1
0.5 0.75
0.125 1
0.25 0.625
END
END
# Web Interface Definition
WEB
# the following "preset_scales" metadata is a list of specific scales
that
# the mapfile is configured for. These values are not used, but can be
# placed in other applications such as ka-Map
(http://ka-map.maptools.org/)
METADATA
"preset_scales"
"2500,7500,12000,17500,35000,75000,125000,200000,400000,750000,2000000,40000
00,7500000,15000000,30000000,60000000"
END
MINSCALE 1 # necessary for CGI point query
TEMPLATE "../HTML_Files/sitemap.html"
IMAGEPATH 'd:/wwwroot/tmp/'
IMAGEURL "/tmp/"
LOG "d:/MapLogs/mapserver.log"
#ERROR "../maperror.htm"
END
# Projection Definition
PROJECTION
"init=epsg:4269"
END
# MyPoint
LAYER
NAME "MyPoint"
TYPE Annotation
STATUS DEFAULT
METADATA
"wms_title" "MyPoint" ##required
END
CLASS
COLOR -1 0 0
STYLE
COLOR 255 0 0
OUTLINECOLOR 255 255 0
SYMBOL 'star'
SIZE 20
END
LABEL
FONT "Arial"
TYPE TRUETYPE
ANTIALIAS TRUE
COLOR 0 0 0
BACKGROUNDCOLOR 220 220 220
OFFSET 10 0
SIZE 10
POSITION lr
END
END
END
END #mapfile
Any help would be greatly appreciated.
Chip Taylor
Prepared Response, inc
