[mapserver-users] Dynamic SQL
Pietro Giannini
pgiannini at bytewise.it
Tue Oct 14 04:28:25 EDT 2008
pls post the entire template, with javascript if exist.
ciao
................pg
On Mar, Ottobre 14, 2008 09:42, mark balman wrote:
> Hi All
> Many thanks to Pietro Giannini and David Fawcett for your help but I
> am still struggling with getting a dynamic sql statement to work. I
> have gone back to trying a simple sql statement in the layer
> definition which works fine like this:
> LAYER
> CONNECTIONTYPE postgis
> NAME "kbapoly"
> CONNECTION "user="" password="" dbname=kba host=localhost"
> DATA "the_geom from (select gid, intname, the_geom from kbapoly where
> intname = 'Tibesti massif') as myquery using SRID=4326 using unique
> gid"
> STATUS OFF
> TYPE POLYGON
> TEMPLATE "templates/kbas.html"
> CLASS
> COLOR 255 0 0
> END
> HEADER "templates/kbas_header.html"
> FOOTER "templates/kbas_footer.html"
> END
> However, if I try the following
> LAYER
> NAME "kbapoly"
> intname = %qtest%) as myquery using SRID=4326 using unique gid"
> STATUS OFF
> TYPE POLYGON
> CLASS
> COLOR 255 0 0
> END
> END
> Together with the following in the template file:
> <input type="hidden" name="Name" value="[qtest]">
> <p><b>IntName: </b><br>
> <textarea name="IntName" rows=2 cols=5>[qtest]</textarea>
> <p>
> <hr>
> This returns the following error
> [Mon Oct 13 16:54:53 2008].386000 msDrawMap(): Image handling error.
> Failed to draw layer named 'kbapoly'.
> [Mon Oct 13 16:58:49 2008].733000 prepare_database(): Query error.
> Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE
> mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
> (select gid, intname, the_geom from kbapoly where intname = %qtest%)
> as myquery WHERE the_geom && setSRID('BOX3D(-179.699499165275
> -120.200333889816,180.300500834725 119.599332220367)'::BOX3D, 4326 )'
> Postgresql reports the error as 'ERROR: syntax error at or near "%"
> LINE 1: ...d, intname, the_geom from kbapoly where intname = %qtest%) a...
> Am I missing something obvious and doing something wrong?
> Any further suggestions would be gratefully received
> Thanks
> Mark
> mapserver-users at lists.osgeo.org
