[mapserver-users] dynamic sql
mark balman
mark.balman at gmail.com
Tue Oct 14 09:20:45 EDT 2008
Hi all
Many thanks for your iputs to this. I have managed to get the simple
query as follows working;
DATA "the_geom from (select gid, intname, the_geom from kbapoly where
intname = '%mquery%') As myquery using SRID=4326 using unique gid"
It was a simple case of quoting the %mquery% (thought I had tried that..)
Now I want to move onto my original query that allows a user to enter
a latitude, longitude and a distance and show all polygons that fall
within the given buffer distance
e.g.
DATA "the_geom FROM (select * from kbapoly where
st_distance(the_geom,GeomFromText('Point(0 1)',4326)) < 6) AS myquery
I have tried the following:
DATA "the_geom FROM ( '%mquery%') AS myquery using SRID=4326 using unique gid
and entering the appropriate sql into the text box
select * from kbapoly where st_distance(the_geom,GeomFromText('Point(0
1)',4326)) < 6
returns the error message:
msDrawMap(): Image handling error. Failed to draw layer named
'kbapoly'. prepare_database(): Query error. Error executing POSTGIS
DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR
FOR SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
from ('%(mquery)%') AS myquery WHERE the_geom &&
setSRID('BOX3D(-179.699499165275 -120.200333889816,180.300500834725
119.599332220367)'::BOX3D, 4326 )' Postgresql reports the error as
'ERROR: syntax error at or near "'%(mquery)%'" LINE 1:
...ection(force_2d(the_geom)),'NDR'),gid::text from ('%(mquery)... ^
I am going to have a go at using Pietro Giannini idea of using his
javascript idea, any more insights would be most welcomed
Thanks again
Mark
