[mapserver-users] WMS don't load
Daniel Morissette
dmorissette at mapgears.com
Mon Oct 20 10:37:44 EDT 2008
Hi Steve,
I'm starting to run out of ideas... do you still get Curl error code 6
in all cases? Perhaps double-check and make sure that the directory
specified in your IMAGEPATH parameter exists and is writable by the web
user... this directory is used to temporarily store the image received
from the remote WMS server before it is included in the final output.
Daniel
Steve.Toutant at inspq.qc.ca wrote:
> Sounds like a DNS config problem on your server... can you double-check
> your network settings?
> There is no proxy, no firewall the DNS seems ok since I can ping and get
> to http://atlas.gc.ca
> Did you try opening the URL using I.E. directly on the server that
> produces the error?
> YES and the image shows up.
> I also tried with this WMS that everyone knows
> LAYER
> NAME "prov_bound"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:42304"
> "wms_name" "prov_bound"
> "wms_server_version" "1.1.1"
> "wms_format" "image/gif"
> END
> END
> Same behaviour. I got a blank image. If I add a layer based on a
> shapefile, I see the shapefile but not the wms.
> The Os is Windows Server 2003 R2 SP2 Multilingue and IE6
> Steve
> /Steve Toutant, M. Sc./
> Analyste en géomatique
> Secteur environnement
> Direction des risques biologiques, environnementaux et occupationnels
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144_
> __steve.toutant at inspq.qc.ca_ <mailto:steve.toutant at inspq.qc.ca>_
> __http://www.inspq.qc.ca_ <http://www.inspq.qc.ca/>
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
