[mapserver-users] WMS don't load
Steve.Toutant at inspq.qc.ca
Mon Oct 20 13:32:40 EDT 2008
Are you familiar with curl? I don't what is it and whait it is supposed to
return.
I downloaded curl.exe anyway but I need help. What is the url I should
send?
I tried
curl.exe
http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=400&BBOX=-80.9516220735786,44.92,-57.1183779264214,62.78&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
But I just get a bunch of error
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 5.0.2-AoC OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP O
UTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDA
L INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF" onload="parent.window.ctl.displayErrorMessage();">
mapserv(): Web application error. Traditional BROWSE mode requires a
TEMPLATE in
the WEB section, but none was provided.
</BODY></HTML>'REQUEST' is not recognized as an internal or external
command,
operable program or batch file.
'SERVICE' is not recognized as an internal or external command,
Invalid parameter - /gif
'STYLES' is not recognized as an internal or external command,
'HEIGHT' is not recognized as an internal or external command,
'VERSION' is not recognized as an internal or external command,
'SRS' is not recognized as an internal or external command,
'WIDTH' is not recognized as an internal or external command,
'BBOX' is not recognized as an internal or external command,
'TRANSPARENT' is not recognized as an internal or external command,
'EXCEPTIONS' is not recognized as an internal or external command,
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081020/243a0433/attachment-0001.html
