[mapserver-users] RE: itemquery, itemnquery, qstring struggles
Jim.Haug at state.sd.us
Wed Oct 22 11:52:53 EDT 2008
Anybody have any ideas? Is the problem in the map file layer setup?
-----Original Message-----
Sent: Monday, October 20, 2008 9:01 PM
To: mapserver-users at lists.osgeo.org
Subject: itemquery, itemnquery, qstring struggles
I've run into a brick wall on this. I've been trying to incorporate
itemquery in a mapserver, first just through a simple test page that
does a quick query. The test page is a simplified form of the itemquery
in the test suite. If I use the qitem setting I get a
"msDBFGetItemIndex(): DBASE file error. Item '[SITE_NO]' not found"
error. If I drop the qitem, I get either the first item in the data, or
in the case of an itemnquery, all of the data.
What I'm doing is setting up a mapserver for archaeological site data in
South Dakota. The query will let a user enter an archaeological site
number (i.e. 39RO0005). In the test case, the server should find the
site and give just a list of the site number it found; eventually I'll
work it into zooming in on the site on the map. The problem is, that the
search either ends up in an error (above) or it returns site '39AU0001',
which is the first site in the dataset. If I try itemnquery, I get all
19,000 sites.
Here is the test web page:
<html>
<head>
<title>ItemQuery test</title>
</head>
<body>
<p>
<form name="test" method="get" action="/cgi-bin/mapserv"> <input
type="hidden" name="map" value="/gisdata/sd/sd_x.map"> <input
type="hidden" name="mode" value="itemquery"> <input type="hidden"
name="qlayer" value="sites"> <input type="hidden" name="qitem"
value="SITE_NO">
Site: <input type="text" name="qstring" maxlength="50"> <input
type="submit" value="Go!">
</form>
</body>
</html>
and here is the layer part of the map file:
LAYER
NAME 'sites'
TYPE POLYGON
DATA '/gisdata/sd/arch/sites.shp'
METADATA
qstring_validation_pattern '.'
END
STATUS OFF
OPACITY 50
PROJECTION
"init=epsg:4326"
END
LABELITEM "SITE_NO"
LABELMAXSCALEDENOM 48000
CLASS
NAME 'sites'
TEMPLATE "/var/www/sd/templates/sites.html"
LABEL
COLOR 96 64 64
END
STYLE
SYMBOL 0
SIZE 3
OUTLINECOLOR 64 64 64
COLOR 200 64 64
END
END
HEADER "/var/www/sd/templates/sites_h.html"
FOOTER "/var/www/sd/templates/sites_f.html"
END
I've tried a few different qstring validation templates, but none of
them seem to work. The line in the address on the browser I get from the
server is:
http://hawken/cgi-bin/mapserv?map=/gisdata/sd/sd_x.map&mode=itemquery&ql
ayer=sites&qstring=39ro0005
I'm stumped. I don't know what I'm doing wrong. Any suggestions,
corrections, ridicule, whatever?
-Jim Haug
