[mapserver-users] Problems With Google Earth WMS view
Alexandre Dube
adube at mapgears.com
Thu Oct 23 08:53:52 EDT 2008
Hi David,
> can define a resolution for the output image?
No, but your can change the image size ( height and width ) in your GE
Link. Default values are 512 X 512. You could change those to 1024 X
1024 and you'll get a nicer image.
> problems with transparency on different zoom level
Are you using your own WMS service ? If so, I don't know which
OUTPUTFORMAT you're using but I had png with agg and didn't have this
problem. If you have more than one "image/png" MIMETYPE, put this one
on top.
OUTPUTFORMAT
NAME "agg"
MIMETYPE "image/png"
DRIVER AGG/PNG
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
END
Hope this can helps.
Cheers
Alexandre
David Martinez Morata wrote:
> Hello.
> I create a WMS for GE and I found some estrange things.
> In my Map file I don't define a background colour and I could like to
> be Transparent, but...
> At some levels I have the transparent image and at other levels I
> don't have it I don't really understand Wat is happening.
> I have 3 Layer in different zoom levels, The first One it's a line
> layer and the others are Points layers.
> And in some areas of my map I found problems with transparency If i
> put in some area i have the transparency but if i change a littel bit,
> the bacgruond becomes with.
> And just one question:
> Thanks
> mapserver-users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
