[mapserver-users] MS-SQL / OGR Query Length Problem
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 23 23:47:01 EDT 2008
Ben Madin wrote:
> Roughly, it would seem that between about 1600 and 1700 characters of
> SQL kills the process. It can be very simple query (just straight data),
> and shorter more complex queries work. cutting excess white space can
> make a difference.
> So, is it a limit of OGR or ODBC that I can't find any reference to. I
> can't see that it is a problem with SQL Server, and I have had (I think)
> longer SQL queries working using postgis...
> My question is, does anyone know where this might be breaking /
> happening? (bonus points if you know whether it is a configuration
> setting that we could tune!)
Ben,
I have reviewed the OGR ODBC driver and I see no obvious point at which
a long query should be a problem. I have also skimmed the MapServer core
and php_mapscript code and I see no obvious problem.
I assume you are placing the SQL query in the DATA statement in the
map file?
I would suggest a few steps to try and isolate this:
o See if you can reproduce it against other ODBC datasources.
o See if you can reproduce it with mapserv instead of php_mapscript
o See if you can reproduce it with just OGR and no MapServer.
If you can reproduce the problem in a form that I can run at my end without
undue complexity, I'd be willing to dig in somewhat deeper.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
