[mapserver-users] problem with gdaladdo
Holger Schiebold
hschiebold at codematix.de
Fri Oct 24 03:46:46 EDT 2008
If anybody interested in, i fixed that problem with a little workaround
#!/bin/sh
# usage gdaladdo.sh file algo level
i=2
while [ $i -le $3 ]
do
gdaladdo -r $2 $1 $i
i=`expr $i + 1`
done
With such a little script each overview level is computed from the
original and so you have the best quality in each downsampled image.
But know comes my next problem - when i am using such a tiff with
overviews in mapserver he takes the wrong level i think. I wrote numbers
in each level so that i can identify which overview mapserver/gdal
takes. In my mapfile i use "399 541" as mapsize which is exactly the
size of level 18 in my pyramid but mapserver takes level 10 which size
is 717 x 974 and so the output of mapserver is not in the quality i
expect. How does mapserver/gdal decides which level of the pyramid he
uses and can i modify this?
thanks in advance
> Hi everyvone,
> I have a problem with gdaladdo while preprocessing raster images. For
> the output of raster images in a Mapserver application I use gdaladdo
> to build overviews of an image that represents Germany (gdaladdo -r
> average test.tif 2 4 8 16 32 64 128 256 512 1024). Typically just the
> first 4 levels are used in the application. To get better output
> results from Mapserver I used the processing method
> "resample=average". But the problem for high quality output in the
> Mapserver application seems to be the great difference between the
> levels of the overviews. So I tried to build overviews with gdaladdo
> -r average test.tif 2 3 4 5 6 7 .... 20. But now I have the problem
> that at the same zoomlevels in mapserver and in the pyramid (e.g.
> image at 500x500 pixel) the quality of the image is worse than in
> former case. Maybe gdaladdo does compute the next level not from the
> original image but from the previous level in the pyramid? Is there a
> possibility to build the each overview from original image to get the
> best qualty in downsampled images?
> thanks in advance
> Holger Schiebold _______________________________________________
> mapserver-users at lists.osgeo.org
