[MAPSERVER-USERS] mapserver MSVC2005 development package
available to download (was mssql2008 binary test package available to
download)
BrainDrain
paulborodaev at gmail.com
Fri Oct 24 03:23:45 EDT 2008
That's great! Thanks.
One question.
As long as I'm windows developer, spoilt by visual studio:
how to debug an app using IDE when building performed by makefile? When no
VS project/solution file available? How you doing this? (tools/methods
(debug console output? without 'watch window'?)).
Best regards,
Paul
Tamas Szekeres wrote:
> Here is my daily snapshot including the fast cgi support:
> http://vbkto.dyndns.org:1280/tests/release-1400-20081023.zip
> I've created a development package to compile mapserver from the sources:
> http://vbkto.dyndns.org:1280/tests/release-1400-dev.zip
> You can use the following steps to compile mapserver.
> 1. Extract the contents to a directory (for example
> "C:\builds\release-1400-dev")
> 2. Open Microsoft Visual Studio 2005 Command Prompt
> 3. > cd C:\builds\release-1400-dev
> 4. > nmake -f makefile.vc ms MS_DIR=mapserver
> BASE_DIR=C:\builds\release-1400-dev
> 5. > nmake -f makefile.vc ms-sql2008 MS_DIR=mapserver
> 5. > nmake -f makefile.vc ms-csharp MS_DIR=mapserver
> This package is based on the development version of gdal and
> mapserver, but you can download the stable version of gdal and
> mapserver sources in the base directory if you require a stable
> version build
> In this case you must specify these directories for MS_DIR and
> GDAL_DIR at the command like, like:
>> nmake -f makefile.vc gdal GDAL_DIR=gdal-1-5
>> nmake -f makefile.vc ms MSL_DIR=mapserver-5-2
> If you require a corresponding package for the MSVC2003 based builds
> let me know.
> Best regards,
> Tamas
> 2008/10/20 BrainDrain <paulborodaev at gmail.com>:
>> Thank you very much, Tamas.
>> getFeature works fine now.
>> But can I ask you for one more favour. Could you compile with fastcgi
>> support (ideally with all ms4w production release flags) or share 'your
>> working buildkit' (this just will be great!, not only for me) because I
>> still have problems with compiling ms4w(( but I need sql2008 support
>> feature
>> as soon as it possible for my work. I would be very appreciate.
>>> Folks,
>>> Yes, I've run into the same issue when using the getFeature method
>>> with the driver. Here is the corresponding ticket I've created:
>>> http://trac.osgeo.org/mapserver/ticket/2795
>>> Attached the C# test case with this ticket:
>>> http://trac.osgeo.org/mapserver/attachment/ticket/2795/Program.cs
>>> I've fixed this issue in the SVN-trunk and the stable branch, here is
>>> my daily snapsot of the binaries you can test with:
>>> http://vbkto.dyndns.org:1280/tests/release-1400-20081018.zip
>>> If you encounter further problems with the driver don't hesitate to
>>> file a ticket describing the issue.
>>> Just for a note: This driver doesn't make any character encodings with
>>> the values retieved as plain byte arrays from MSSQL, however your
>>> default database setting corresponds to the
>>> 1251 codepage, so explicit character conversion may be required in C#,
>>> like:
>>> byte[] bytes = Encoding.Convert(Encoding.Unicode, Encoding.Default,
>>> Encoding.Unicode.GetBytes(shape.getValue(k)));
>>> string str = Encoding.GetEncoding(1251).GetString(bytes);
>>> Best regards,
>>> Tamas
>>> 2008/10/17 BrainDrain <paulborodaev at gmail.com>:
>>>> hmm
>>>>>>could you provide an example to this
>>>> how can I help If I use mapscript?
>>>> [WebService(Namespace = "http://www.wem.volgadmin.ru/wemlib")]
>>>> [WebServiceBinding(ConformsTo = WsiProfiles.None)]
>>>> [ScriptService]
>>>> public class MapParser : System.Web.Services.WebService
>>>> [WebMethod(EnableSession = true)]
>>>> [ScriptMethod(UseHttpGet = true)]
>>>> public object RequestFeatureAttributes(object mapIndex, object
>>>> layerIndex, int[] featureIndexes, string[] fieldNames, bool envelope)
>>>> mapObj map;
>>>> layerObj layer = null;
>>>> shapeObj shape;
>>>> int entryIndex = -1, i, j, len = featureIndexes.Length;
>>>> object[] res = new object[len];
>>>> Dictionary<string, object> valueBag, record;
>>>> if (Util.isNumeric(mapIndex.ToString(),
>>>> NumberStyles.Integer))
>>>> mapIndex = (object)Convert.ToInt32(mapIndex);
>>>> if (Util.isNumeric(layerIndex.ToString(),
>>>> layerIndex = (object)Convert.ToInt32(layerIndex);
>>>> KeyValuePair<string, object> entry =
>>>> Util.getEntry((Dictionary<string, object>)Session["maps"],
>>>> (mapIndex.GetType() == typeof(int)) ? mapIndex :
>>>> Util.normalizePath((string)mapIndex), out entryIndex);
>>>> map = (mapObj)entry.Value;//.clone()
>>>> if (layerIndex.GetType() == typeof(int))
>>>> layer = map.getLayer((int)layerIndex);
>>>> else
>>>> if (layerIndex.GetType() == typeof(string))
>>>> layer = map.getLayerByName((string)layerIndex);
>>>> layer.open();
>>>> object def;
>>>> List<int> fieldIndexes = new List<int>();
>>>> List<string> list = new List<string>();
>>>> if (fieldNames != null)
>>>> for (i = 0; i < layer.numitems; i++)
>>>> if
>>>> (((ICollection<string>)fieldNames).Contains(layer.getItem(i)))
>>>> fieldIndexes.Add(i);
>>>> for (i = 0; i < len; i++)
>>>> try
>>>> using (shape = layer.getFeature(featureIndexes[i],
>>>> -1))
>>>> //here exception occurs
>>>> string[] values;
>>>> if (fieldNames.Length > 0)
>>>> list.Clear();
>>>> for (j = 0; j < fieldIndexes.Count; j++)
>>>> list.Add(shape.values[fieldIndexes[j]]);
>>>> values = list.ToArray();
>>>> else
>>>> values = new string[1] {
>>>> featureIndexes[i].ToString() };
>>>> else
>>>> values = shape.values;
>>>> valueBag = new Dictionary<string, object>();
>>>> for (j = 0; j < values.Length; j++)
>>>> valueBag[j.ToString()] = values[j];
>>>> if (envelope)
>>>> record = new Dictionary<string, object>();
>>>> if (len > 1)
>>>> record[featureIndexes[i].ToString()] =
>>>> (object)valueBag;//?
>>>> else
>>>> record[entryIndex.ToString() + ' ' +
>>>> layer.index.ToString() + ' ' + featureIndexes[i].ToString()] =
>>>> res[i] = record;
>>>> else
>>>> res[i] = valueBag;
>>>> catch { }
>>>> layer.close();
>>>> return (len > 1) ? ((envelope) ? new Dictionary<string,
>>>> object>() { { entryIndex.ToString() + ' ' + layer.index.ToString(), res
>>>> : (object)res) : res[0];
>>>> Again access violation exception after modifying mapfile.
>>>> Sql profiler says that query batch (select convert(varchar(max),
>>>> STATUS),convert(varchar(max), STAGE),convert(varchar(max), id),GEOM
>>>> from
>>>> dbo.Construct where id = 190748) completed successfully
>>>>> 2008/10/16 BrainDrain <paulborodaev at gmail.com>:
>>>>>> -without "WITH(INDEX..." in mapfile data section - mem corruption
>>>>>> exception
>>>>>> on "shape = layer.getFeature(featureIndexe, -1)" after successful
>>>>>> execution
>>>>>> of queryByPoint (querying the largest polygon in my geodb);
>>>>> I didn't encounter any memory corruption error here, could you provide
>>>>> an example to this?
>>>>> I've set up your database with IIS and apache with the following
>>>>> links:
>>>>> http://vbkto.dyndns.org:1280/cgi-bin/mapserv.exe?mode=map&map=test2008.map
>>>>> http://vbkto.dyndns.org:1080/cgi-bin/mapserv.exe?mode=map&map=test2008.map
>>>>>> -with using "WITH(INDEX...":
>>>>>> msMSSQL2008LayerGetShape(): Query error. Error executing MSSQL2008
>>>>>> SQL
>>>>>> statement: select convert(varchar(max), STATUS),convert(varchar(max),
>>>>>> STAGE),convert(varchar(max), id),GEOM from dbo.Construct
>>>>>> WITH(INDEX(SIndx_Construct_geometry_geom)) where id = 190748
>>>>>> -[Microsoft][ODBC SQL Server Driver][SQL Server]Query processor could
>>>>>> not
>>>>>> produce a query plan because of the hints defined in this query.
>>>>>> Resubmit
>>>>>> the query without specifying any hints and without using SET
>>>>>> FORCEPLAN.
>>>>>> When I'm trying to execute this select statement in man. studio -
>>>>>> error
>>>>>> message - the same.
>>>>>> I think because where clause don't contains conditions related to
>>>>>> spatial
>>>>>> index used in 'WITH' hint.
>>>>> You're right, just looking into the code here is a possible solution:
>>>>> DATA "GEOM from dbo.Construct USING UNIQUE id USING SRID=0 USING INDEX
>>>>> SIndx_Construct_geometry_geom"
>>>>> Best regards,
>>>>> Tamas
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> View this message in context:
>>>> http://www.nabble.com/mssql2008-binary-test-package-available-to-download-tp19956347p20027820.html
>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> http://www.nabble.com/mssql2008-binary-test-package-available-to-download-tp19956347p20065718.html
View this message in context: http://www.nabble.com/mapserver-MSVC2005-development-package-available-to-download-%28was-mssql2008-binary-test-package-available-to-download%29-tp20129726p20145478.html
