[mapserver-users] WMS TIME using postgis time index,
problem with GetFeatureInfo
Maarten Plieger
plieger at knmi.nl
Fri Oct 24 11:19:10 EDT 2008
Hi All,
I use a postgis database filled with files and their corresponding
dates. This makes it possible to use WMS Time requests. This works very
well, except for the GetFeatureInfo request. When I do GetFeatureInfo on
a certain location I get this message:
"msSHPOpenFile(): Unable to acces file.
(/mapdata/RADNL25TIME)"
The data is raster data, and has nothing to do with Shapes...
This is a part of the mapfile of the layer:
TILEITEM "path" #path is a column in postgis table with varchar of the
filepath to each image
TILEINDEX "RADNL25TIME"
METADATA
"wms_timeextent"
"2008-10-24T00:00:00Z/2008-10-24T12:00:00Z/PT5M"
"wms_timeitem" "datetime" #datetime is a column in
postgis table of type timestamp
"wms_timedefault" "2008-10-24T00:00:00Z"
END
Is this a known bug, or am I doing something wrong?
When I use a file directly instead of the PostGIS table, GetFeature info
returns the correct results.
Regards,
Maarten Plieger
Maarten Plieger
KNMI, R&D Information and Observation Technology, De Bilt
(t) +31 30 2206330
