[MAPSERVER-USERS] [Postgis] Intersection on requested data
G. Tiemens
Gerben.Tiemens at grontmij.nl
Wed Oct 29 11:12:28 EDT 2008
Hello all,
Is it possible to do an intersection on the requested data?
I want to make a data query to the postgis, where the data will be
intersected and delivered to mapserver for display process.
Here is what i already reached:
CONNECTIONTYPE postgis
CONNECTION 'host=127.0.0.1 user=postgres password=postgres dbname=OM'
DATA "the_geom FROM kl_l USING UNIQUE gid USING SRID = 28992"
FILTER "ST_Intersects(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
387820 , 165651 387813 , 165672 387759 , 165598 387800 , 165607 387820
))' , 28992) )"
This works fine. The data returned is the features that intersect. But this
returns the whole feature, instead of the intersection part itself.
So i tried to get the intersection:
DATA "ST_Intersection(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
))' , 28992) ) FROM kl_l USING UNIQUE gid USING SRID = 28992"
))' , 28992) )"
The full query works fine on the postgis database:
select ST_Intersection(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
))' , 28992) ) FROM kl_l where ST_Intersects(kl_l.the_geom ,
ST_GeomFromText('POLYGON((165607 387820 , 165651 387813 , 165672 387759 ,
165598 387800 , 165607 387820 ))' , 28992) )
The part where mapserver is complaining is the single quote just before
POLYGON in the DATA statement.
I tried single quotes inside double quotes, tried double quotes inside
single quotes, both give the same error.
Is there any way of retrieving the intersected features?
Greets
Gerben
View this message in context: http://www.nabble.com/-Postgis--Intersection-on-requested-data-tp20229230p20229230.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
