[mapserver-users] Combine Spatial & attribute queries
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Thu Sep 4 02:35:17 EDT 2008
I have done code for spatial Query..
This is Spatial Query..
protected void ContriesEnvelop()
layer = MapFunction.Map.getLayerByName("Countries"); // Get
Layer by name
string strSubRegionsClassItem = "cntry_name=";
string strDropDownSelectedItem = "'" +
lstContries.SelectedItem.Text + "'";
string strQuery = strSubRegionsClassItem +
strDropDownSelectedItem;
res = layer.queryByAttributes(MapFunction.Map, "CNTRY_NAME",
strQuery, 1);
if (res == (int)EnumMap.RESULT_CODE.MS_SUCCESS)
results = layer.getResults();
if (results != null)
resulCacheObj = results.getResult(0);
layer.open();
layer.close();
using (results = layer.getResults())
if (results != null && results.numresults > 0)
// calculating the extent of the results
if (query_bounds == null)
{ query_bounds = new rectObj(results.bounds.minx,
results.bounds.miny, results.bounds.maxx, results.bounds.maxy, 0); }
else
if (results.bounds.minx < query_bounds.minx)
{ query_bounds.minx = results.bounds.minx; }
if (results.bounds.miny < query_bounds.miny)
{ query_bounds.miny = results.bounds.miny; }
if (results.bounds.maxx > query_bounds.maxx)
{ query_bounds.maxx = results.bounds.maxx; }
if (results.bounds.maxy > query_bounds.maxy)
{ query_bounds.maxy = results.bounds.maxy; }
if (zoomToResults)
try
MapFunction.Map.setExtent(query_bounds.minx,
query_bounds.miny, query_bounds.maxx, query_bounds.maxy);
catch (NullReferenceException exp)
MapFunction.IsMapInDirectory = true;
This Method is for Getting Non Spatial query and populates data in Listbox .
based on Listbox data zooms to the shape..
public void PopulateContries()
strSelectedItem = lstSubRegions.SelectedValue;
conn = new NpgsqlConnection(_AppSetting.GetConnection);
conn.Open();
String strSql = string.Format(_AppSetting.GetCntryCmdText,
strSelectedItem);
dataAdapter = new NpgsqlDataAdapter(strSql, conn);
dataSet = new DataSet();
dataAdapter.Fill(dataSet, _AppSetting.GetCntryTblName);
lstContries.DataSource =
dataSet.Tables[_AppSetting.GetCntryTblName];
lstContries.DataTextField = _AppSetting.GetCntryDataFieldName;
lstContries.DataBind();
conn.Close();
Is it same you want?let me know..But I am using Postgresql..
Thanks and Regards
Venkat.
India
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Hallgren,
Johan
Sent: Thursday, September 04, 2008 11:49 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Combine Spatial & attribute queries
Hello
I'm working with Mapserver 5.2 and with the C# interface.
Now I use a Oracle spatial layer and we would like to query the layer with a
combination of spatial and attribute queries. Today a first use queryByRect
and then queryByAttribute. Two queries will be sent to Oracle and the
resultCache will only have the result of the latest query.
How can I solve this? Primarily I only will send one query to the database,
both with the spatial and the attribute part.
br
Johan
Johan Hallgren
Logica
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.hallgren at logica.com
http://www.logica.se <http://www.logica.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080904/0581029d/attachment-0001.html
