[mapserver-users] Re: JOIN in a mapfile from a shapefile to a
MySQL database
Minka Stoyanova
minka.stoyanova at gmail.com
Thu Sep 18 09:35:18 EDT 2008
Dear Charles, dear list,
As I said, I used your piece of map-file code and made the connection. Now I
try the same but with another shapefile to another table in the same
database, and I receive a segmentation fault of the Apache!
Here follows the code from the map-file:
- this works just fine - the simple layer from the shapefile:
LAYER # States point layer 1 begins here from the shapefile
NAME "cpoints"
DATA controlpoints_v04
STATUS ON
TYPE POINT
CLASS
SYMBOL 'circle'
SIZE 8
COLOR 0 0 255
OUTLINECOLOR 243 255 17
END
END # States point layer 1 ends here
- this works fine:
NAME "synoptic_stations"
CONNECTIONTYPE ogr
CONNECTION "../data/ESRI/UTM/synoptic_stations.shp"
DATA "SELECT * FROM synoptic_stations LEFT JOIN
'MYSQL:meteo,host=myhost,user=mysqluseraccount,password=mysqluserpasswd'.bgc
ON synoptic_stations.A = bgc.sin_kod"
STATUS ON
TYPE POINT
CLASS
SYMBOL 'circle'
SIZE 8
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
- this fails with a segmentation fault:
NAME "cpoints"
CONNECTIONTYPE ogr
CONNECTION "../data/ESRI/mt/controlpoints_v04.shp"
DATA "SELECT * FROM controlpoints_v04 LEFT JOIN
'MYSQL:meteo,host=myhost,user=mysqluseraccount,password=mysqluserpasswd'.controlpoint
ON controlpoints_v04.ID=controlpoint.CODENUM"
STATUS ON
TYPE POINT
CLASS
SYMBOL 'circle'
SIZE 8
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
So: the database is the same, mysql user and passwd are the same, the
connection is from the same Apache server with the same php mapscript
application. The shapefiles are different and the tables in the database are
different.
Where could be the problem?
Thanks!
Minka
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080918/ed13fb20/attachment.html
