R: [MAPSERVER-USERS] Debian Oracle10g OCI
Leandro Dardini
l.dardini at comune.prato.it
Mon Sep 15 09:01:57 EDT 2008
I use something like this:
./configure -with-oraclespatial=/usr/lib/oracle/10.2.0.3/client64 -with-proj -with-wfsclient -with-wmsclient -with-gdal -with-ogr -without-tiff -without-pdf -with-threads -with-freetype
make
make shared
I compile Oracle Spatial Support also for GDAL.
Leandro
> -----Messaggio originale-----
> Da: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Per conto di
> Umberto Nicoletti
> Inviato: lunedì 15 settembre 2008 14.46
> A: dzizes
> Cc: mapserver-users at lists.osgeo.org
> Oggetto: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
> You have to recompile mapserver with the:
> --with-oraclespatial=[path to oracle home]
> option. That's all that is needed to enable oracle spatial
> support in mapserver.
> HTH,
> Umberto
> On Mon, Sep 15, 2008 at 2:05 PM, dzizes <dzizes451 at gmail.com> wrote:
> > Hi,
> > I've installed mapserver on Debian (lenny distribution).
> I've managed
> > to create mapfile based on shp data and successfully send a wms
> > request to get a map. I seems that mapserver works fine.
> > I've also installed oracle-ex and I can connect to my
> Oracle via sqlplus.
> > However, when I request wms (to a map file pointing to Oracle10g) I
> > receive the following:
> > msDrawMap(): Image handling error. Failed to draw layer
> named 'test'.
> > msOracleSpatialLayerOpen(): OracleSpatial error.
> OracleSpatial is not
> > supported
> > I've found that I need OCI installed and configured properly, but
> > there is no clear tutorial.
> > Please provide me a some step by step guide.
> > Greets,
> > Michal
> > View this message in context:
> > http://www.nabble.com/Debian-Oracle10g-OCI-tp19491636p19491636.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
