[mapserver-users] Mapserver and GDB files
Paul Ramsey
pramsey at cleverelephant.ca
Tue Sep 23 01:23:34 EDT 2008
Write an ArcGIS script to do all the work :) ArcGIS can export to
Shape file and can read lyr files.
Heck: http://arcscripts.esri.com/details.asp?dbid=12766
P.
On Mon, Sep 22, 2008 at 10:20 PM, Raivo Alla <snaperski at gmail.com> wrote:
> Thank you all very much for answers.
> I am working on a project, where all data is in .gdb files and styles in
> ArcGIS .lyr format.
> I guess both - getting .gdb and .lyr files working in mapserver environment
> - are at the moment not possible?
> So I must convert convert .gdb files (using FME maybe?) to some readable
> format like shapefiles (if possible) and
> just type manually mapserver symbology files... uhh.
> Raivo
> On Mon, Sep 22, 2008 at 7:19 PM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
>> On Sep 22, 2008, at 9:59 AM, Frank Warmerdam wrote:
>>> Fawcett, David wrote:
>>>> .gdb files are ESRI's new File Geodatabase proprietary format. I am
>>>> quite sure that OGR/FWTools does not support it.
>>> David,
>>> Ah thanks. Indeed they are not supported and it is hard to imagine they
>>> will be supported for a while. ESRI has indicated in the past that they
>>> intend to provide an open mechanism to access the file geodatabase and
>>> that
>>> is still likely to happen at some point. However, I think this would be
>>> quite a few months away at best.
>> Hmmm, and if ESRI provides it, then, like SDE, it probably won't be
>> available for OSX (or other linux platforms?). Bleh.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>> - Marvin
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
