[mapserver-users] transparent pixmaps in python mapscripts
Dan Little
danlittle at yahoo.com
Wed Sep 24 11:02:08 EDT 2008
You could render the map with a known background color, and then use PIL to create a transparent GIF from the image.
If you can use white as the bg color then you can convert the image to a 2 color bitmap in memory, and then use it as a mask to perform the transparency composition.
----- Original Message ----
> From: Daniel Morissette <dmorissette at mapgears.com>
> To: "Fawcett, David" <David.Fawcett at state.mn.us>
> Cc: mapserver-users at lists.osgeo.org
> Sent: Wednesday, September 24, 2008 8:45:19 AM
> Subject: Re: [mapserver-users] transparent pixmaps in python mapscripts
> David,
> TRANSPARENCY ALPHA works only between layers drawn using map.draw() in a
> single pass. If you call layer.draw() for each layer in a loop in your
> script then TRANSPARENCY ALPHA has no effect and that could explain the
> problem you are encountering.
> Daniel
> Fawcett, David wrote:
> > I am using a pixmap symbol to mark a point using Python MapScript v. 5.2.
> > The image has a transparent background. When I use the symbol with
> > MapServer CGI, I the transparency works. When I use the symbol in
> > MapScript, I get a black background for the symbol, no transparency.
> > Here is how I am creating the symbol:
> > img = mapscript.imageObj(/symbols/redcross.png', 'GD/PNG')
> > # create the symbol using the image
> > symbol = mapscript.symbolObj('from_img')
> > symbol.type = mapscript.MS_SYMBOL_PIXMAP
> > symbol.setImage(img)
> > symbol_index = mymap.symbolset.appendSymbol(symbol)
> > I also tried to add this to the layer, but it made no difference either:
> > inline_layer.transparency = mapscript.MS_GD_ALPHA
> > Here is a gdalinfo report on the symbol image:
> > Driver: PNG/Portable Network Graphics
> > Files: redcross.png
> > Size is 32, 32
> > Coordinate System is `'
> > Image Structure Metadata:
> > INTERLEAVE=PIXEL
> > Corner Coordinates:
> > Upper Left ( 0.0, 0.0)
> > Lower Left ( 0.0, 32.0)
> > Upper Right ( 32.0, 0.0)
> > Lower Right ( 32.0, 32.0)
> > Center ( 16.0, 16.0)
> > Band 1 Block=32x1 Type=Byte, ColorInterp=Red
> > Mask Flags: PER_DATASET ALPHA
> > Band 2 Block=32x1 Type=Byte, ColorInterp=Green
> > Band 3 Block=32x1 Type=Byte, ColorInterp=Blue
> > Band 4 Block=32x1 Type=Byte, ColorInterp=Alpha
> > Any ideas on how to get a pixmap symbol with a transparent background
> > using python mapscript?
> > Thanks,
> > David.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Daniel Morissette
> http://www.mapgears.com/
