[mapserver-users] Re: Transparency via WMS request?
Robert Sanson
SansonR at asurequality.com
Wed Sep 24 18:39:31 EDT 2008
Is it possible to get layer transparency when outputformat=PDF?
Thanks,
Robert Sanson
>>> "Roger André" <randre at gmail.com> 25/09/2008 10:36 a.m. >>>
Thanks to some help from a fellow GIS developer, I think I've narrowed
the problem down to the OUTPUTFORMAT section of my mapfile. Changing
from the AGG to GD driver seemed to take care of the problem. Will need
to do some additional futzing to see if I can get it working with AGG.
On Wed, Sep 24, 2008 at 1:38 PM, Roger André <randre at gmail.com> wrote:
Ok, this is driving me bonkers. I have a raster image with nodata
values set to be transparent. When I make requests to this layer in
"mode=map", it works beautifully, and the nodata values are
transparent.
http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/temp/temp.map&mode=map
However, when I try to view the same data via a WMS request, the nodata
values are displayed in black.
- http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/temp/temp.map
&SERVICE=WMS
&version=%221.1.122
&REQUEST=GetMap
&LAYERS=imagery
&STYLES=
&BBOX=-180,-90,180,90
&WIDTH=600
&HEIGHT=500
&FORMAT=png
&SRS=epsg:4326
I have tried doing a couple of things to fix this, none of which has
worked:
- added "wms_transparent" "TRUE" to METADATA section of LAYER
- added "&TRANSPARENT=TRUE" to the end of the WMS request
- made sure that in OUTPUTFORMAT I have all of these:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "TRANSPARENT=ON"
FORMATOPTION "INTERLACE=OFF"
TRANSPARENT ON
END #end outputformat
Please, can anyone tell me what I'm missing?
Thanks,
Roger
Click here (
https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
) to report this email as spam.
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080925/b01d031b/attachment-0001.html
