[mapserver-users] Error while getting flash output
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Apr 1 09:55:22 EDT 2009
The error message seems to indicate that you did not build MapServer
with ming support. Can you do mapserv -v on the command like and check
if you have OUTPUT=SWF?
Subha Ramakrishnan wrote:
> Hi All,
> I am trying to get flash output from mapserver. I have compliled my
> mapserver 5.2.2 with flash support.
> But when i request for a layer, I am getting the following error:
> "loadOutputFormat(): General error message. OUTPUTFORMAT clause
> references driver SWF, but this driver isn't configured. "
> This is my url:
> "http://localhost/cgi-bin/mapserv?MAP=flashlayer.map&TRANSPARENT=true&LAYERS=flashlayer&FORMAT=image%2Fswf&PROJECTION=EPSG%3A4326&REPROJECT=false&
> UNITS=m&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&
> BBOX=4235678.0892222235,859902.5737739494,13628260.123222224,4404134.700666138&WIDTH=1920&HEIGHT=724"
> Mapfile is as follows:(initial part with projection , extent etc truncated)
> OUTPUTFORMAT
> NAME "swf"
> MIMETYPE "application/x-shockwave-flash"
> DRIVER "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
> END
> layer
> name flashlayer
> connectiontype postgis
> connection "user= postgres dbname=flashtable host=localhost"
> type polygon
> group world
> dump true
> METADATA
> "RESULT_FIELDS" "__ibp__id"
> "SWFDUMPATTRIBUTES" "__ibp__id"
> END
> template "template.html"
> projection
> "init=epsg:4326"
> end
> transparency 65
> status on
> data "topology from flashtest using unique id using SRID = -1"
> classitem "country"
> class
> name "INDIA"
> expression "INDIA"
> style
> color 139 242 144
> outlinecolor 000 000 000
> end
> end
> end
> Can some one please guide me as how to get the output in flash after
> enabling the support?
> Thanks a lot for any help.
> Subha
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
