[mapserver-users] Mapscript shapeObj->toWKt()
orms_shapeObjfromWkt problem.
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Apr 2 16:05:52 EDT 2009
Will look at getting the patch into 5.4 before the first release candidate.
Steve
>>> On 4/1/2009 at 3:54 PM, in message <C5F93ECA.1B49C%pmoen at nd.gov>, "Moen, Paul
T." <pmoen at nd.gov> wrote:
> I changed my Geos to version 3.0.3 and the error changed from "Segmentation
> fault" to "Bus error".
> I also looked at the ticket Assefa indicated below and am wondering if that
> was related to the buffer or to the same problem I am having? The script I
> am having problems does nothing more than create a new shape object from a
> wkt and then re-output the wkt from the shape object. The object seems to be
> created fine, because I can get the number of lines with $drawnShp->numlines.
> I can also create a new shape object with the other shape object constructer
> as follows and the output works.
> <?php
> dl('php_mapscript.so');
> $drawnShp = ms_newShapeObj(MS_SHAPE_POLYGON);
> $line = ms_newLineObj();
> $line->addXY(1207657,478875);
> $line->addXY(1208230,478275);
> $line->addXY(1207452,477811);
> $line->addXY(1207043,478520);
> $drawnShp->add($line);
> error_log($drawnShp->numlines);
> error_log($drawnShp->towkt());
> Is this specifically a problem with Geos 3.1 and the function
> ms_shapeObjFromWkt()? Which version of Mapserver will have the patch in
> ticket 2929?
> Thanks,
> Paul
> On 4/1/09 12:33 PM, "Yewondwossen Assefa" <yassefa at dmsolutions.ca> wrote:
> Not helping here but I have tested your script on windows with Mapserver
> 5.2.2 and 5.4 and the script runs ok. The geos version used in this
> case is geos 2.2.3. Do you know what version of geos you are using?
> There was a recent fix done toward geos support in MapServer and the
> problem from what I remember was occurring with geos 3.1 (Is that
> correct Tom ?)
> (http://trac.osgeo.org/mapserver/ticket/2929
> Best Regards
> Moen, Paul T. wrote:
>> I get a segmentation fault when I run the following simple script with
>> PHP MapScript on Mac OSX 10.5.6 running the latest versions from
>> www.kyngchaos.com
>> #!/usr/local/php5cgi/bin/php -q
>> <?php
>> $newwkt = 'MULTIPOLYGON(((1207657 478875,1208230 478275,1207452
>> 477811,1207043 478520,1207657 478875)))';
>> $drawnShp = ms_shapeObjFromWkt($newwkt);
>> echo $drawnShp->toWKT();
>> /Library/WebServer/CGI-Executables/mapserv -v
>> MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE
>> The only output is;
>> Segmentation fault
>> The php version is 5.2.9 and the same thing happens with php versions
>> 5.2.8, 5.2.5.
>> *MapServer Version *MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG
>> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
>> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> *PHP MapScript Version *($Revision: 7937 $ $Date: 2008-09-30 07:37:46
>> -0700 (Tue, 30 Sep 2008) $)
>> Anybody else run into this this error? How do I get more debug information?
>> Thanks,
>> Paul
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
