[mapserver-users] mapserver with mapinfo gis data file
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Thu Apr 2 04:34:41 EDT 2009
Can you debug vs.net application, so that you come to know the error.I
think the error is from your connection path.. you have given like
"Mapserver(5.2.1)-Mapscript" mapserve may not accept the same path.Please
clear with the path.
Thanks,
Venkat
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of meenu
Sent: Thursday, April 02, 2009 1:32 PM
To: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] mapserver with mapinfo gis data file
hi friend
i added 4 mapinfo files (admin_o.MAP,admin_o.TAB,admin_o.DAT,admin_o.ID )
in to the data folder of TutorialMapServerSolution project...then i added
the coding in to the csharptutorial.map file is as follows...no error is
getting...but this layer is not showing in to the map...what is the reason
behind this any idea???is any other OGR files required to be added in to
this project???
LAYER
NAME "admin_o"
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "C:\Mapserver(5.2.1)-Mapscript\data\admin_o.TAB"
STYLEITEM "AUTO"
CLASS
NAME "admin_o"
END
END # Layer
with regards
View this message in context:
http://n2.nabble.com/mapserver-with-mapinfo-gis-data-file-tp2568491p2573915.
html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
