[mapserver-users] MapServer on OS X - getcababilities no xml
output?
Asle Benoni
asle.benoni at gmail.com
Thu Apr 2 15:00:22 EDT 2009
Thanks. I tried to change to "service=WFS" and got an XML with some warnings
that I think I understood in the MapServer docs links you sent. I have a
problem with proxy.cgi in GeoServer not understanding this ContentType. Do
you think I could enter a new MIME type in my OS X Servers Apache? How
should that look like? Any Idea?
2009/4/1 Daniel Morissette <dmorissette at mapgears.com>
> Asle Benoni wrote:
>> When I use this URL
>> http://localhost/cgi-bin/demo?request=getcapabilities&service=wms&version=1.1.1&map=/Library/WebServer/Documents/Naturkart/kulturminnekart/apps/demo/demowms.map<
>> I get a file downloaded "demo.map" with no file type. This is on Windows
>> and from my Mac (demo without the .map extension and fileType:*
>> application/vnd.ogc.wms_xml*). The file is an XML file so when I change the
>> suffix to .xml it works. Is this correct?
> Yes, that's correct, but for WMS, not WFS: application/vnd.ogc.wms_xml is
> the expected MIME Type for WMS GetCapabilities responses. OGC has moved back
> to using text/xml in later versions of its specs as those custom MIME Types
> caused all sorts of trouble with very little benefits.
> Note that in your example you are using SERVICE=WMS and not WFS, is this
> really what you wanted?
> Is MapServer out-of-the-box a WFS service?
> Yes and no. Out of the box it will respond to WFS (and WMS) requests, but
> if your mapfile lacks some configuration information then it may not behave
> according to spec. See the WMS and WFS server docs for all the details:
> http://www.mapserver.org/ogc/wms_server.html
> http://www.mapserver.org/ogc/wfs_server.html
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090402/a0f59615/attachment.html
