[mapserver-users] setFilter problem (c#)
    Paul james
    pauljame at gmail.com
    Mon Apr  6 07:31:12 PDT 2009
Hi Tamas!
It´s a Postgis layer...And the extent is fine...
Any ideia?
Thanks
On Sat, Apr 4, 2009 at 3:52 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Paul,
> Which data source are you using? It highly depends on the type of the data
> source how the filter is interpreted by mapserver.
> Are you sure there are matching features within the extent you have?
> Best regards,
> Tamas
> 2009/4/3 Paul james <pauljame at gmail.com>
>> Hello guys...
>> I got a problem...
>> My code :
>> var _filter = "('[gid]'='10')";
>> var _layer = _map.MapObj.getLayerByName("X");
>> var _lC = _layer.clone();
>> _lC.setFilter(_filter);
>> _lC.name = "Dummy";
>> _lC.status = 1;
>> _lC.getClass(0).getStyle(0).color.setRGB(0, 250, 250);
>> _lC.getClass(0).getStyle(0).outlinecolor.setRGB(0, 250, 0);
>> _map.MapObj.insertLayer(_lC, _map.MapObj.numlayers-1);
>> No error, but the filter layer doest appear... If I took of the filter
>> line, the layer shows up ok...
>> Any idea?
>> []´s
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090406/92b02880/attachment.htm>
More information about the MapServer-users
