[mapserver-users] setFilter problem (c#)
    Tamas Szekeres
    szekerest at gmail.com
    Mon Apr  6 08:11:27 PDT 2009
Then the filter is passed directly to the database in the SQL WHERE clause.
You might want to enable logging the SQL statements at the server and see
what gets executed when the layer is drawn.
Best regards,
Tamas
2009/4/6 Paul james <pauljame at gmail.com>
> Hi Tamas!
> It´s a Postgis layer...And the extent is fine...
> Any ideia?
> Thanks
> On Sat, Apr 4, 2009 at 3:52 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Paul,
>> Which data source are you using? It highly depends on the type of the data
>> source how the filter is interpreted by mapserver.
>> Are you sure there are matching features within the extent you have?
>> Best regards,
>> Tamas
>> 2009/4/3 Paul james <pauljame at gmail.com>
>>>  Hello guys...
>>> I got a problem...
>>> My code :
>>> var _filter = "('[gid]'='10')";
>>> var _layer = _map.MapObj.getLayerByName("X");
>>> var _lC = _layer.clone();
>>> _lC.setFilter(_filter);
>>> _lC.name = "Dummy";
>>> _lC.status = 1;
>>> _lC.getClass(0).getStyle(0).color.setRGB(0, 250, 250);
>>> _lC.getClass(0).getStyle(0).outlinecolor.setRGB(0, 250, 0);
>>> _map.MapObj.insertLayer(_lC, _map.MapObj.numlayers-1);
>>> No error, but the filter layer doest appear... If I took of the filter
>>> line, the layer shows up ok...
>>> Any idea?
>>> []´s
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090406/a136d37d/attachment.htm>
More information about the MapServer-users
