[mapserver-users] getExtent(c#) with Postgis data ...
Paul james
pauljame at gmail.com
Tue Apr 7 15:00:18 EDT 2009
Thanks!
But I resolved my problem using shapeObj, without OGR...
My code:
_layer.open();
shapeObj _shape = new shapeObj((int)_layer.type);
_layer.getShape(_shape, -1, Convert.ToInt32(__id));
_map.extent.maxx = _shape.bounds.maxx +0.1;
_map.extent.maxy = _shape.bounds.maxy + 0.1;
_map.extent.minx = _shape.bounds.minx - 0.1;
_map.extent.miny = _shape.bounds.miny - 0.1;
On Tue, Apr 7, 2009 at 3:29 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Paul,
> You can refer to the ogrinfo C# sample application in the gdal source tree:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/ogrinfo.cs
> Best regards,
> Tamas
> 2009/4/7 Paul james <pauljame at gmail.com>
> Thanks Tamas...
>> But now I´m a little lost... Am I supposed to create a OGR layer?
>> Do you have any sample how to get extent´s layer using OGR?
>> P
>> On Mon, Apr 6, 2009 at 6:30 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>> Choose a package with the best match for your compiler and architecture
>>> from here:
>>> http://vbkto.dyndns.org:1280/sdk/index.html
>>> Best regards,
>>> Tamas
>>> 2009/4/6 Paul james <pauljame at gmail.com>
>>>> Where can I find ogr_csharp.dll ?
>>>> Thanks Tamas!
>>>> Paul
>>>> On Mon, Apr 6, 2009 at 6:22 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>> Paul,
>>>>> Unfortunately this function is not implemented by the MapServer postgis
>>>>> driver, you might want to use the OGR C# API (ie. ogr_csharp.dll) for this
>>>>> purpose.
>>>>> Best regards,
>>>>> Tamas
>>>>>> All value from getExtent (Postgis layer) is : 3.4028234663852886E+38
>>>>>> Is it a bug?
>>>>>> On Mon, Apr 6, 2009 at 5:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>>> Why don't? That function have already been exposed for *layerObj*with the following signature:
>>>>>>> *public rectObj getExtent(void)*
>>>>>>> Best regards,
>>>>>>> Tamas
>>>>>>>> Hello, It seems that getExtent (c#) is not implemented...
>>>>>>>> Any other solution to get extent of a layer using mapscript?
>>>>>>>> Paul
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090407/ff79f9b9/attachment-0001.html
