[mapserver-users] getExtent(c#) with Postgis data ...
Matej
matej at matnet.net
Tue Apr 7 15:04:50 EDT 2009
this might not be directly connected but I am planning to build a client desktop app which should be able to connect to the PostGIS db that is running on the remote server and display objects from it / add new etc.
Is this possible in C# with fwtools without the need to have the Mapserver running on every client computer?
Thanks and sorry for interrupting,
Matej
----- Original Message -----
To: Paul james
Cc: mapserver-users at lists.osgeo.org
Sent: Tuesday, April 07, 2009 8:29 PM
Subject: Re: [mapserver-users] getExtent(c#) with Postgis data ...
Paul,
You can refer to the ogrinfo C# sample application in the gdal source tree:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/ogrinfo.cs
Best regards,
Tamas
2009/4/7 Paul james <pauljame at gmail.com>
Thanks Tamas...
But now I´m a little lost... Am I supposed to create a OGR layer?
Do you have any sample how to get extent´s layer using OGR?
P
On Mon, Apr 6, 2009 at 6:30 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
Choose a package with the best match for your compiler and architecture from here:
http://vbkto.dyndns.org:1280/sdk/index.html
Best regards,
Tamas
2009/4/6 Paul james <pauljame at gmail.com>
Where can I find ogr_csharp.dll ?
Thanks Tamas!
Paul
On Mon, Apr 6, 2009 at 6:22 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
Paul,
Unfortunately this function is not implemented by the MapServer postgis driver, you might want to use the OGR C# API (ie. ogr_csharp.dll) for this purpose.
Best regards,
Tamas
All value from getExtent (Postgis layer) is : 3.4028234663852886E+38
Is it a bug?
On Mon, Apr 6, 2009 at 5:56 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
Why don't? That function have already been exposed for layerObj with the following signature:
public rectObj getExtent(void)
Best regards,
Tamas
Hello, It seems that getExtent (c#) is not implemented...
Any other solution to get extent of a layer using mapscript?
Paul
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090407/17515f92/attachment.html
