[mapserver-users] getExtent(c#) with Postgis data ...
Tamas Szekeres
szekerest at gmail.com
Tue Apr 7 16:17:03 EDT 2009
Matej
Yes it's definitely the case.
You application should set a reference to the managed mapscript_csharp.dll
assembly and it will implicitly load furher unmanaged dlls to provide the
desired functionality.
Best regards,
Tamas
2009/4/7 Matej <matej at matnet.net>
> Hi,
> this might not be directly connected but I am planning to build a client
> desktop app which should be able to connect to the PostGIS db that is
> running on the remote server and display objects from it / add new etc.
> Is this possible in C# with fwtools without the need to have the Mapserver
> running on every client computer?
> Thanks and sorry for interrupting,
> Matej
> ----- Original Message -----
> *From:* Tamas Szekeres <szekerest at gmail.com>
> *To:* Paul james <pauljame at gmail.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Tuesday, April 07, 2009 8:29 PM
> *Subject:* Re: [mapserver-users] getExtent(c#) with Postgis data ...
> Paul,
> You can refer to the ogrinfo C# sample application in the gdal source tree:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/ogrinfo.cs
> Best regards,
> Tamas
> 2009/4/7 Paul james <pauljame at gmail.com>
>> Thanks Tamas...
>> But now I´m a little lost... Am I supposed to create a OGR layer?
>> Do you have any sample how to get extent´s layer using OGR?
>> P
>> On Mon, Apr 6, 2009 at 6:30 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>> Choose a package with the best match for your compiler and architecture
>>> from here:
>>> http://vbkto.dyndns.org:1280/sdk/index.html
>>> Best regards,
>>> Tamas
>>> 2009/4/6 Paul james <pauljame at gmail.com>
>>>> Where can I find ogr_csharp.dll ?
>>>> Thanks Tamas!
>>>> Paul
>>>> On Mon, Apr 6, 2009 at 6:22 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>> Paul,
>>>>> Unfortunately this function is not implemented by the MapServer postgis
>>>>> driver, you might want to use the OGR C# API (ie. ogr_csharp.dll) for this
>>>>> purpose.
>>>>> Best regards,
>>>>> Tamas
>>>>>> All value from getExtent (Postgis layer) is : 3.4028234663852886E+38
>>>>>> Is it a bug?
>>>>>> On Mon, Apr 6, 2009 at 5:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>>> Why don't? That function have already been exposed for *layerObj*with the following signature:
>>>>>>> *public rectObj getExtent(void)*
>>>>>>> Best regards,
>>>>>>> Tamas
>>>>>>>> Hello, It seems that getExtent (c#) is not implemented...
>>>>>>>> Any other solution to get extent of a layer using mapscript?
>>>>>>>> Paul
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090407/cd10cae6/attachment.html
