[mapserver-users] changing rendered color of
layer dynamically?
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Apr 9 09:56:27 EDT 2009
Versions 5+ use syntax like:
map.layer[india_states].class[ANDHRA%20PRADESH].style[0]=COLOR+255+0+0
There was a typo in my old message. Since you're doing WMS you could/should use SLD.
Steve
>>> Subha Ramakrishnan <subha at gslab.com> 04/09/09 1:02 AM >>>
The solution didn't work for me.
This is my url:
"http://localhost/cgi-bin/mapserv?MAP=india_states.map&TRANSPARENT=true&LAYERS=india_states&map.layer[india_states].class[ANDHRA%20PRADESH].style[0].color+255+0+0&FORMAT=image%2Fpng&
PROJECTION=EPSG%3A4326&REPROJECT=false&UNITS=m&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage
&SRS=EPSG%3A900913&BBOX=8305796.970622223,1252337.1900454492,9558141.241822222,2504681.4612454493&WIDTH=256&HEIGHT=256"
I get his error: "getSymbol(): Symbol definition error. Parsing error
near ([):(line 1) ".
Is there anything wrong in my url?
Thanks for any help.
Subha
Steve Lime wrote:
> Nikos: There can be more than one style in a class to you'd need the array notation there too:
> &map.layer[oikismoi].class[oikismoi].style[0].color+230+34+35
> Does that work?
> Steve
>>>> <nikos at maich.gr> 10/06/08 8:18 AM >>>
> Hello all,
> I've been scratching my head as to how to change the color that a layer
> maybe rendered via a form. My users want to select which color the layers
> should be rendered.
> Would appreciate a bit of insite. I'm using FW MS 5.1-dev
> I've tried, according to the docs, using layer and class names as well as
> layer and class index and neither work...
> &map.layer[oikismoi].class[oikismoi].style.color+230+34+35
> &map.layer[0].class[0].style.color+230+34+35
> In MS 4.something, I used to use "map_layer_0_class_0_color=255+0+0"
> successfully
> I've also tried to use something like
> CLASS # layer color change
> EXPRESSION '%layer_color%'
> style
> backgroundcolor 128 128 128
> color 2 2 220
> outlinecolor 150 150 150
> end
> END
> to at least statically test a substitution, but fail...
> below is a snip from my mapfile,
> sincerely,
> nikos
> LAYER
> debug 5
> classitem "OBJECTID"
> data "LANDUNIT_KARDITSA"
> footer "LANDUNIT_KARDITSA_footer.html"
> group "LANDUNIT_KARDITSA"
> header "LANDUNIT_KARDITSA_header.html"
> labelcache on
> labelitem "OBJECTID"
> name "LANDUNIT_KARDITSA"
> postlabelcache true
> status on
> type polygon
> OPACITY 70
> # 1 class LANDUNIT_KARDITSA
> class
> name "KARDITSA"
> style
> #color 133 234 21
> color 22 200 22
> outlinecolor 50 50 50
> end
> template "LANDUNIT_KARDITSA_query.html"
> end
> end
> LAYER
> DEBUG 5
> data "oikismoi"
> footer "oikismoi_footer.html"
> group "oikismoi"
> header "oikismoi_header.html"
> labelcache on
> name "oikismoi"
> postlabelcache true
> status on
> type polygon
> # 1 class oikismoi
> class
> name "oikismoi"
> style
> backgroundcolor 0 128 128
> color 22 122 233
> outlinecolor 0 0 0
> end
> template "oikismoi_query.html"
> end
> end
> mapserver-users at lists.osgeo.org
