[mapserver-users] Generating a symbol with a fixed size
Adrian Popa
adrian_gh.popa at romtelecom.ro
Thu Apr 9 04:25:15 EDT 2009
Hello everybody,
I'm using mapserver v4.10 and I'm trying to display a circle symbol that
has a fixed radius (in meters) that shows the coverage area over a map.
The main problem is setting the radius so it would change and cover the
same area with different zoom levels (more clearly - I want the radius
to be 40m independent of the zoom selected).
Is it possible to do with mapserver?
The data (points) where I want to draw this symbol is available as an
ESRI shapefile layer (as POINT data).
Thanks in advance,
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
