[mapserver-users] msIO_getStdoutBufferBytes(),
gdBuffer in mapscript perl
Daniel Morissette
dmorissette at mapgears.com
Fri Apr 10 09:41:32 EDT 2009
Just a guess since I'm not very familiar with the Perl SWIG stuff, but
maybe the patch from this ticket could help?
http://trac.osgeo.org/mapserver/ticket/2962
If I'm not mistaken it solves a similar problem with the
imageObj.getBytes return value, and I presume the problem you
encountered needs a similar solution.
Daniel
Felipe Alcacibar wrote:
> Hi, i'm trying to implement a wms server with a perl api of mapscript
> but i cannot understand how msIO_getStdoutBufferBytes() work
> in the docs msIO_getStdoutBufferBytes() function return the binary
> content of the current output but i cannot see that, when i dump with
> Data::Dump::Streamer i got:
> -> $_p_gdBuffer1 = bless( \do { my $v = 152646680 }, '_p_gdBuffer' );
> I go to read the sources of the mapscript perl implementation and i
> found a struct with properties data and size, but i cannot get that i
> got that when i try to dump data.
> -> Can't locate object method "data" via package "_p_gdBuffer" at
> /home/counter/mscacherd/maptest.pl line 36.
> How it works in perl, how i can get the data from the gdBuffer perl class?
> Thanks in advice.
> Greetings
> Felipe
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
