[mapserver-users] problem with truetype fonts.
Joseph4774
Joseph4774 at hotmail.com
Sat Apr 11 17:56:00 EDT 2009
Hello again
Does no one have an idea as how to solve my problem or is my explanation of the problem not clear enough maybe?
Hi Everyone,
I have problem with location of truetype fonts when I choice outputFormat PDF . It seems that with outputFormat PDF mapserver choices the lower left corner of the bounding box of the glyph and not the center center of the glyph.But everything works correctly when i change the outputFormat to PNG.
I attached a folder with three test files to give more information about my problem. one is the true font Iam using for the test the secound one is the png file and the third is hte pdf file.
SendToPDFLib.zip
I hope i've explained my problem well and iam sorry for my bad English.
Iam using csharp_script.dll .net solution and the PDFlib.dll for PDF output. and her is a part of the code that i user to generate pdf file map:
mapObj MSMap = new mapObj("mapfile");
outputFormatObj format = new outputFormatObj("pdf", "pdf");
MSMap.setOutputFormat(format);
imageObj img = MSMap.drawQuery();
img.save("imgFullPath", null);
img.Dispose();
and the test mapfile :
MAP
NAME TEST
STATUS ON
SIZE 740 460
EXTENT 693618 6171475 693855 6171703
UNITS METERS
FONTSET "/proj/Test/div/font.txt"
IMAGETYPE png24
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
IMAGEMODE RGB
EXTENSION "png"
END
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
WEB
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/output"
IMAGEURL "/tmp/"
# LOG "/tmp/gmap.log"
METADATA
"TITLE" "Informationer på Kort, Morsø Kommune"
END
END
LAYER
GROUP Ledninger
NAME Ledning
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "/proj/test/linie.TAB"
#STYLEITEM "AUTO"
CLASS
NAME ledninger
STYLE
COLOR 0 0 255
WIDTH 2
END
END
END
LAYER
GROUP Knuder
NAME Knuder
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "/proj/Test/linie.TAB"
CLASS
NAME knuder
STYLE
COLOR 255 0 0
OUTLINECOLOR 255 0 0
#BACKGROUNDCOLOR 0 0 0
SIZE 30
Width 1
SYMBOL "test01"
END
END
END
SYMBOL
NAME "test01"
TYPE TRUETYPE
FONT elgraf2009
POSITION CC
FILLED false
ANTIALIAS true
CHARACTER "2"
END
END MAP
View this message in context: http://n2.nabble.com/problem-with-truetype-fonts.-tp2600843p2622058.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
