[mapserver-users] changing rendered color of layer dynamically?
Subha Ramakrishnan
subha at gslab.com
Fri Apr 10 05:02:02 EDT 2009
Hi Steve,
Thanks for the help.It worked fine..:)
Subha
Steve Lime wrote:
> Versions 5+ use syntax like:
> map.layer[india_states].class[ANDHRA%20PRADESH].style[0]=COLOR+255+0+0
> There was a typo in my old message. Since you're doing WMS you could/should use SLD.
> Steve
>>>> Subha Ramakrishnan <subha at gslab.com> 04/09/09 1:02 AM >>>
> The solution didn't work for me.
> This is my url:
> "http://localhost/cgi-bin/mapserv?MAP=india_states.map&TRANSPARENT=true&LAYERS=india_states&map.layer[india_states].class[ANDHRA%20PRADESH].style[0].color+255+0+0&FORMAT=image%2Fpng&
> PROJECTION=EPSG%3A4326&REPROJECT=false&UNITS=m&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage
> &SRS=EPSG%3A900913&BBOX=8305796.970622223,1252337.1900454492,9558141.241822222,2504681.4612454493&WIDTH=256&HEIGHT=256"
> I get his error: "getSymbol(): Symbol definition error. Parsing error
> near ([):(line 1) ".
> Is there anything wrong in my url?
> Thanks for any help.
> Subha
> Steve Lime wrote:
>> Nikos: There can be more than one style in a class to you'd need the array notation there too:
>> &map.layer[oikismoi].class[oikismoi].style[0].color+230+34+35
>> Does that work?
>> Steve
>>>>> <nikos at maich.gr> 10/06/08 8:18 AM >>>
>> Hello all,
>> I've been scratching my head as to how to change the color that a layer
>> maybe rendered via a form. My users want to select which color the layers
>> should be rendered.
>> Would appreciate a bit of insite. I'm using FW MS 5.1-dev
>> I've tried, according to the docs, using layer and class names as well as
>> layer and class index and neither work...
>> &map.layer[oikismoi].class[oikismoi].style.color+230+34+35
>> &map.layer[0].class[0].style.color+230+34+35
>> In MS 4.something, I used to use "map_layer_0_class_0_color=255+0+0"
>> successfully
>> I've also tried to use something like
>> CLASS # layer color change
>> EXPRESSION '%layer_color%'
>> style
>> backgroundcolor 128 128 128
>> color 2 2 220
>> outlinecolor 150 150 150
>> end
>> END
>> to at least statically test a substitution, but fail...
>> below is a snip from my mapfile,
>> sincerely,
>> nikos
>> LAYER
>> debug 5
>> classitem "OBJECTID"
>> data "LANDUNIT_KARDITSA"
>> footer "LANDUNIT_KARDITSA_footer.html"
>> group "LANDUNIT_KARDITSA"
>> header "LANDUNIT_KARDITSA_header.html"
>> labelcache on
>> labelitem "OBJECTID"
>> name "LANDUNIT_KARDITSA"
>> postlabelcache true
>> status on
>> type polygon
>> OPACITY 70
>> # 1 class LANDUNIT_KARDITSA
>> class
>> name "KARDITSA"
>> style
>> #color 133 234 21
>> color 22 200 22
>> outlinecolor 50 50 50
>> end
>> template "LANDUNIT_KARDITSA_query.html"
>> end
>> end
>> LAYER
>> DEBUG 5
>> data "oikismoi"
>> footer "oikismoi_footer.html"
>> group "oikismoi"
>> header "oikismoi_header.html"
>> labelcache on
>> name "oikismoi"
>> postlabelcache true
>> status on
>> type polygon
>> # 1 class oikismoi
>> class
>> name "oikismoi"
>> style
>> backgroundcolor 0 128 128
>> color 22 122 233
>> outlinecolor 0 0 0
>> end
>> template "oikismoi_query.html"
>> end
>> end
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
