[mapserver-users] TR: Blank map
Clément MONIER
Clement.MONIER at v-trafic.com
Tue Apr 14 10:33:17 EDT 2009
Thanks for answering.
I've already tried your second option (lon/lat order switch) but it didn't change anything (blank map)
The second request leads to :
"WMS server error. Unsupported SRS namespace (only EPSG and AUTO currently supported)."
Clement
-----Message d'origine-----
De : Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Envoyé : mardi 14 avril 2009 15:20
À : Clément MONIER
Cc : mapserver-users at lists.osgeo.org
Objet : Re: [mapserver-users] TR: Blank map
Hi There,
You should be able to get the result entering something like:
LAYERS=layer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&CRS=CRS:84&BBOX=2.48,48.82,2.50,48.84&WIDTH=512&HEIGHT=512
or
&VERSION=1.3.0&LAYERS=layer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&CRS=EPSG:4326&BBOX=48.8,2.48,48.84,2.50&WIDTH=512&HEIGHT=512
I have also opened a bug on the fact that using SRS instead of CRS
should throw an exception (http://trac.osgeo.org/mapserver/ticket/2979).
I will correct that for the 5.4.1. release.
Let me know.
Best Regards,
Clément MONIER wrote:
> Thanks for your answer Jukka.
> I did always use "VERSION=1.3.0" in my WMS request and encountered no problem with it until now.
> But I've read this and I got scared :
> http://mapserver.org/development/rfc/ms-rfc-30.html#coordinate-systems-and-axis-orientation
> Though I've tried to enter bbox parameter with lat/lon or lon/lat formats, it didn't change anything.
> Update : I got a correct map using shp2img.
> Any help or lead would be appreciated
> Thanks a lot
> De : mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Rahkonen Jukka
> Envoyé : mardi 14 avril 2009 11:35
> À : Clément MONIER; mapserver-users at lists.osgeo.org
> Hi,
> Any possibility that it could have something to do with WMS version 1.3 that flipped the coordinate axis order? Did you also previously use WMS 1.3?
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>> Clément MONIER
>> Lähetetty: 14. huhtikuuta 2009 11:26
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] TR: Blank map
>> This issue (see below) is still active with MS 5.4 rc1.
>> Can anyone help me ?
>> Thanks
>> Clement
>> de Clément MONIER Envoyé : mardi 7 avril 2009 10:55 À :
>> mapserver-users at lists.osgeo.org Objet : [mapserver-users] Blank map
>> Hi,
>> MapServer returns blank images since I upgraded to MS4W 2.3.1
>> + mapserver_ms4w-5.4.0-beta4.
>> Though I've followed the upgrade tips and changed my mapfiles :
>> http://lists.osgeo.org/pipermail/mapserver-users/2009-March/06
>> 0600.html
>> You'll find as attachment a very simple test case (.map + shapefiles).
>> Here's the request that should (and used to) return a map :
>> http://localhost/cgi-bin/mapserv.exe?MAP=C:\ms4w\apps\gmap\htd
>> ocs\test.map&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=l
>> ayer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&SR
>> S=EPSG:4326&BBOX=2.48,48.82,2.50,48.84&WIDTH=512&HEIGHT=512
>> I suspect a projection issue because the following request
>> (with a world-wide bbox) does display some features (look for
>> a small green point on the left side) :
>> S=EPSG:4326&BBOX=-90,0,90,180&WIDTH=512&HEIGHT=512
>> Has anything changed inside the Proj4 library ?
>> Thanks for your help
>> Clément
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
