[mapserver-users] TR: Blank map
    Yewondwossen Assefa
    yassefa at dmsolutions.ca
    Tue Apr 14 08:11:06 PDT 2009
Clément MONIER wrote:
> Sorry, your second option is working well indeed.
great.
> Following to
> http://mapserver.org/development/rfc/ms-rfc-30.html#coordinate-systems-and-axis-orientation
> Long/lat must be inverted
> The map is displayed correctly but
> I think that it will lead to a lot of confusion !
confusion? you must be kidding :)  I agree with you that the axis
inversion might lead to confusion since It is not the way we are used to
work but the specs are defined as such.
Note also that there is some initial doc at the
http://mapserver.org/ogc/wms_server.html#wms-1-3-0-support and any text,
examples you might want to add to ease up the confusion is welcome.
Best Regards,
> -----Message d'origine-----
> De : Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
> Envoyé : mardi 14 avril 2009 15:20
> À : Clément MONIER
> Cc : mapserver-users at lists.osgeo.org
> Objet : Re: [mapserver-users] TR: Blank map
> Hi There,
>   You should be able to get the result entering something like:
> LAYERS=layer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&CRS=CRS:84&BBOX=2.48,48.82,2.50,48.84&WIDTH=512&HEIGHT=512
>   or
> &VERSION=1.3.0&LAYERS=layer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&CRS=EPSG:4326&BBOX=48.8,2.48,48.84,2.50&WIDTH=512&HEIGHT=512
> I have also opened a bug on the fact that using SRS instead of CRS
> should throw an exception (http://trac.osgeo.org/mapserver/ticket/2979).
> I will correct that for the 5.4.1. release.
> Let me know.
> Best Regards,
>> Thanks for your answer Jukka.
>> I did always use "VERSION=1.3.0" in my WMS request and encountered no problem with it until now.
>> But I've read this and I got scared :
>> Though I've tried to enter bbox parameter with lat/lon or lon/lat formats, it didn't change anything.
>> Update : I got a correct map using shp2img.
>> Any help or lead would be appreciated
>> Thanks a lot
>> De : mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Rahkonen Jukka
>> Envoyé : mardi 14 avril 2009 11:35
>> À : Clément MONIER; mapserver-users at lists.osgeo.org
>> Hi,
>> Any possibility that it could have something to do with WMS version 1.3 that flipped the coordinate axis order?  Did you also previously use WMS 1.3?
>> -Jukka Rahkonen-
>>> -----Alkuperäinen viesti-----
>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>>> Clément MONIER
>>> Lähetetty: 14. huhtikuuta 2009 11:26
>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>> Aihe: [mapserver-users] TR: Blank map
>>> This issue (see below) is still active with MS 5.4 rc1.
>>> Can anyone help me ?
>>> Thanks
>>> Clement
>>> de Clément MONIER Envoyé : mardi 7 avril 2009 10:55 À :
>>> mapserver-users at lists.osgeo.org Objet : [mapserver-users] Blank map
>>> Hi,
>>> MapServer returns blank images since I upgraded to MS4W 2.3.1
>>> + mapserver_ms4w-5.4.0-beta4.
>>> Though I've followed the upgrade tips and changed my mapfiles :
>>> http://lists.osgeo.org/pipermail/mapserver-users/2009-March/06
>>> 0600.html
>>> You'll find as attachment a very simple test case (.map + shapefiles).
>>> Here's the request that should (and used to) return a map :
>>> http://localhost/cgi-bin/mapserv.exe?MAP=C:\ms4w\apps\gmap\htd
>>> ocs\test.map&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=l
>>> ayer1&STYLES=&FORMAT=agga&BGCOLOR=0xFFFFFF&TRANSPARENT=True&SR
>>> S=EPSG:4326&BBOX=2.48,48.82,2.50,48.84&WIDTH=512&HEIGHT=512
>>> I suspect a projection issue because the following request
>>> (with a world-wide bbox) does display some features (look for
>>> a small green point on the left side) :
>>> S=EPSG:4326&BBOX=-90,0,90,180&WIDTH=512&HEIGHT=512
>>> Has anything changed inside the Proj4 library ?
>>> Thanks for your help
>>> Clément
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users
