[mapserver-users] Displaying query result on the same page?
kreshna_iceheart at yahoo.com
Tue Apr 21 03:29:58 EDT 2009
I see, thanks!
Is it possible to use the same HTML file for both query and browse? The file contains both browsing parameters ([img], [layer_name], etc) and query parameters ([field_name]).
I think I'll try it.
Warm regards,
-Kresh
--- On Mon, 4/20/09, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> From: Steve Lime <Steve.Lime at dnr.state.mn.us>
> Subject: Re: [mapserver-users] Displaying query result on the same page?
> To: mapserver-users at lists.osgeo.org, "kreshna_iceheart at yahoo.com" <kreshna_iceheart at yahoo.com>
> Date: Monday, April 20, 2009, 1:12 PM
> You can probably do it with
> query/browse templates but the other methods are
> more efficient and provide a better user experience and are
> easier to configure.
> Steve
> >>> On 4/20/2009 at 1:07 AM, in message
> <860869.57172.qm at web110602.mail.gq1.yahoo.com>,
> wrote:
> > Thank you, Steve.
> > It seems frames and/or AJAX are the only way to
> display query result on the
> > same page when using CGI MapServer, am I correct?
> > -Kresh
> > --- On Sun, 4/19/09, Steve Lime <Steve.Lime at dnr.state.mn.us>
> >> Date: Sunday, April 19, 2009, 1:48 AM
> >> For frames you just set the form
> >> target to the frame of interest. You're code is
> quite
> >> close.
> >> Still another option is to use AJAX/AJAST. You
> issue the
> >> query via an XMLHttpRequest and get the
> >> results back in a javascript string or object that
> you can
> >> direct the contents of to a container (e.g. div)
> >> on your page.
> >> Steve
> >> 04/18/09 10:37 AM >>>
> >> I hope this newbie question doesn't bother you.
> >> See, I want to display query result on my map
> page, but if
> >> I use query mode, the query result replaces the
> whole page.
> >> As workaround, I redirect the query result to a
> pop-up page
> >> using the following JavaScript:
> >> function
> toFrame() {
> >> if
> >> (document.mapserv.mode.value ==
> >> "query" || document.mapserv.mode.value ==
> >> "nquery") {
> >> document.mapserv.target = "_blank";
> >> } else {
> >> document.mapserv.target = "_self";
> >> However, I'd also like to display the query result
> as part
> >> of the page (for example, on the lower right of
> the page),
> >> without replacing the entire page with the query
> result.
> >> Is there any way to do such thing using CGI
> MapServer? Or
> >> is PHP MapScript the only way to do it?
> >> I'm thinking about using HTML frames, but I'm
> still at loss
> >> to redirect the query result to a particular
> frame.
> >> Many thanks,
> >> -Kresh
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
