[mapserver-users] mapserver error
Iratxe Lejarreta
iratxe.lejarreta at axios.es
Wed Apr 22 06:53:28 EDT 2009
On Wednesday 22 April 2009 08:54:57 Pano wrote:
> Hi Iratxe,
> Looks like mapserver doesnt know the TNS name 'orcl' that you have defined.
> I assume that the machine where mapserver runs has an oracle client
> installed? Can you log into sql plus i..e sqlplus mddata/<passwd>@orcl from
> a command prompt on this box? I assume you will get the same TNS error.
> Which will mean that your tnsnames.ora file is not set correctly. The file
> should be located under $ORACLE_HOME\network\admin\tnsnames.ora. There
> should be an entry in there like:
> ORCL =
> (DESCRIPTION =
> (ADDRESS_LIST =
> (ADDRESS =
> (PROTOCOL = TCP)
> (HOST = <server_name_or_IP)
> (PORT = <usually_1521>)
> (CONNECT_DATA =
> (SERVER = DEDICATED)
> (SERVICE_NAME = <oracle_service_name>)
> Hope this helps,
> Pano
> Iratxe Lejarreta wrote:
> > Hi,
> > I installed MapServer-5.2.0 on CentOS 5.2 with Oracle 10g, but when I run
> > the
> > WFS service...
> > http://localhost/cgi-
> > bin/mywfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=cities
> > ...the result is:
> > <ServiceExceptionReport version="1.2.0"
> > xsi:schemaLocation="http://www.opengis.net/ogc
> > http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> > <ServiceException code="NoApplicableCode" locator="mapserv">
> > msWFSGetFeature(): WFS server error. ms_error->code not found
> > msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
> > Handlers.
> > Connection failure. Check the connection string. Error: ORA-12154:
> > TNS:could
> > not resolve the connect identifier specified
> > Handlers.
> > TNS:could
> > </ServiceException>
> > </ServiceExceptionReport>
> > Mapfile:
> > MAP
> > NAME WFS_TEST
> > STATUS ON
> > SIZE 400 300
> > EXTENT -180 -90 180 90
> > UNITS METERS
> > IMAGECOLOR 255 255 255
> > WEB
> > METADATA
> > "wfs_title" "WFS TEST"
> > "wfs_onlineresource" "http://localhost/cgi-bin/mywfs?"
> > "wfs_srs" "EPSG:4326"
> > END
> > END
> > PROJECTION
> > "init=epsg:4326"
> > END
> > LAYER
> > NAME cities
> > TYPE POINT
> > CONNECTIONTYPE oraclespatial
> > CONNECTION "MDDATA/*****@orcl"
> > DATA "GEOM FROM CITIES USING UNIQUE FID SRID 4326 VERSION 10g"
> > METADATA
> > "wfs_title" "cities"
> > "gml_featureid" "FID"
> > "gml_include_items" "all"
> > END
> > STATUS ON
> > DUMP TRUE
> > CLASS
> > STYLE
> > OUTLINECOLOR 0 0 0
> > COLOR 0 128 128
> > END
> > END
> > END # Cities
> > END # Map File
> > Somebody can help me?
> > Thanks in advance.
> > Iratxe Lejarreta
> > www.axios.es
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Hi Pano,
Firstly, thanks for your answer!
I have checked all configuration but I continue with the same error:
1.- I haven't got any error in logs.
2.- I installed Oracle Instat Client:
# rpm -Uvh oracle-instantclient-basic-10.2.0.4-1.i386.rpm
I have set the library loading path:
# export LD_LIBRARY_PATH=/usr/lib/oracle/10.2.0.3/client/lib
3.- I can access with sqlplus and sqldeveloper without any problem:
[oracle]$ sqlplus mddata/<passwd>@orcl
4.- $ORACLE_HOME\network\admin\tnsnames.ora file:
ORCL =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS =
(PROTOCOL = TCP)
(HOST = 192.168.2.215)
(PORT = 1521)
(CONNECT_DATA =
(SERVICE_NAME = orcl)
5.- I try to access with the following URL:
http://192.168.2.215/cgi-
6.- ...but the result it's the same:
msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI Handlers.
Connection failure. Check the connection string. Error: ORA-12154: TNS:could
not resolve the connect identifier specified.
</ServiceException>
Do you know where could be wrong?
Thanks for your help!!!!!
Regards,
Iratxe Lejarreta
www.axios.es
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090422/f3b71eb2/attachment-0001.html
