[mapserver-users] GetFeatureINFO errors in Mapserver not occurring
in Geoserver.
Michelle Douvil
mrdouville at shaw.ca
Thu Apr 23 16:59:57 EDT 2009
We have data that is in Oracle 10.2.0.2 Enterprise Edition with ArcSDE 9.1
General Update Patch 3.
We have several spatial views that are causing us issues when GetFeatureINFO
is requested via Mapserver 5.2. The result is an SDE error.
SE_stream_fetch_row(): Invalid parameter value passed to function. (-66).
However, using Geoserver 1.7.3 to the same data the GetFeatureINFO request
is successful. Any thoughts as to why Mapserver has issues but Geoserver
does not?
The Spatial View given in the example below is a simple view (no where
clauses or join statements). We have re-registered the Spatial view with the
sde to make sure the objectid was correct.
Looks like Geoserver 1.7.3 doesn’t mind GetFeatureINFO on
SCHEMA.AEI_AIR_QUALITY_AOI_SVW
Whereas Mapserver 5.2 gets confused.. see examples below
http://server/geoserver/wms?service=wms&request=getFeatureInfo&version=1.1.1&layers=prod:AOIAEI&query_layers=prod:AOIAEI&width=500&height=500&SRS=EPSG:4326&BBOX=-126.94250575451,54.5026638549918,-126.72424645805,54.6394718590618&x=200&y=200&info_format=text/plain
Results for FeatureType 'AOIAEI':
geometry = [GEOMETRY (Polygon) with 22 points]
air_quality_aoi_id = 66
aoi_name = Bulkley Valley / Lakes District
status = Plan Established
feature_code = FF00595000
http://server/mapserver/air-climate?service=wms&request=getFeatureInfo&version=1.1.1&layers=AEI_AIR_QUALITY_AOI_O&query_layers=AEI_AIR_QUALITY_AOI_O&width=500&height=500&SRS=EPSG:4326&BBOX=-126.94250575451,54.5026638549918,-126.72424645805,54.6394718590618&x=200&y=200&info_format=text/plain
GetFeatureInfo results:
Layer 'AEI_AIR_QUALITY_AOI_O'
Content-type: application/vnd.ogc.se_xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msSDELayerGetShape(): SDE error. SE_stream_fetch_row(): Invalid parameter
</ServiceException>
</ServiceExceptionReport>
many thanks for any assistance.
View this message in context: http://n2.nabble.com/GetFeatureINFO-errors-in-Mapserver-not-occurring-in-Geoserver.-tp2686390p2686390.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
